Rings Generated by Elements - Lovett, Example 5.2.1 .... ....
5 replies · 3K views
Math Amateur
MHB
I am reading Stephen Lovett's book, "Abstract Algebra: Structures and Applications" and am currently focused on Chapter 5 ...
I need some help with Example 5.2.1 in Section 5.2: Rings Generated by Elements ...
In the Introduction to Section 5.2.1 (see text above) Lovett writes:
" ... ... $$R$$ denotes the smallest (by inclusion) subring of $$A$$ that contains both $$R$$ and $$S$$ ... ... "Then, a bit later, in Example 5.2.1 concerning the ring $$\mathbb{Z} [ \frac{1}{2} ]$$ Lovett writes:" ... ... It is not hard to show that the set$$\{ \frac{k}{ 2^n} \ | \ k.n \in \mathbb{Z} \}$$is a subring of $$\mathbb{Q}$$. Hence, this set is precisely the ring $$\mathbb{Z} [ \frac{1}{2} ]$$ ... ... ... "BUT ...
How has Lovett actually shown that the set $$\{ \frac{k}{ 2^n} \ | \ k,n \in \mathbb{Z} \}$$ as a subring of $$\mathbb{Q}$$ is actually (precisely in Lovett's words) the ring $$\mathbb{Z} [ \frac{1}{2} ]$$ ... ... ?
... ... according to his introduction which I quoted Lovett says that the ring $$\mathbb{Z} [ \frac{1}{2} ]$$ is the smallest (by inclusion) subring of $$\mathbb{Q}$$ that contains $$\mathbb{Z}$$ and $$\frac{1}{2}$$ ... ...Can someone please explain to me exactly how Lovett has demonstrated this ... ...
... and ... if Lovett has not clearly proved this can someone please demonstrate a proof ...Just one further clarification ... is Lovett here dealing with ring extensions ... ... ?
Hope someone can help ...
Peter
Let R be any subring of the rationals Q that contains both 1/2 and the integers. Let n be any positive integer; induct on n to show ${1\over 2^n}\in R$. (Inductive step: ${1\over 2^n}\in R$ implies ${1\over 2}{1\over 2^n}\in R$ since R is closed under products. Also if n is any non-positive integer, ${1\over 2^n}=2^{-n}$ is an integer and so belongs to R. Again since R is closed under products, $k{1\over 2^n}\in R$. So the given subring is a subset of R.
Thanks for the help johng ...
But i am still a bit puzzled ... I think we have to show that $$\{ \frac{k}{ 2^n} \ | \ k.n \in \mathbb{Z} \}$$ is actually the smallest subring of $$\mathbb{Q}$$ that contains both $$\frac{1}{2}$$ and $$\mathbb{Z}$$ ... ... thus making it equal to or identified with $$\mathbb{Z} [ \frac{1}{2} ]$$ ... ...
How do we accomplish this explicitly and rigorously ...
Can you help further ...
Peter
You have to understand what is meant by the smallest element of a partially ordered set S. This is an element m of S such that $m\leq s$ for any $s\in S$. For example let S be the set of positive even integers ordered by $\leq$. Then 2 is the smallest element of S. How do you prove this?
Let s be any positive even integer. Then s=2q for some $q\geq 1$, and so $2\leq 2q=s$.
Then the above applies directly to the partially ordered set S of subrings of Q that contain 1/2 and the integers (the order on S is $\subseteq$). In my previous post, I said let R be any subring that contains 1/2 and the integers; i.e. let R be any element of S. I proved
$$\{{k\over 2^n}\,: k,n\in Z\}\subseteq R\}$$
Suppose [tex]\{\frac{k}{2^n}|k,n\in Z\}[/tex] were not the smallest ring containing [tex]\frac{1}{2}[/tex] and all integers. That is, there exist some ring, S, that is smaller. Then there must be some integers, k and n, such that [tex]\frac{k}{2^n}[/tex] that is not in S. But, as johng showed, since [tex]\frac{1}{2}[/tex] is in the set, by the multiplication is closed, and induction on n, [tex]\frac{1}{2^n}[/tex] is in the set. And then, since k is an integer [tex]\frac{k}{2^n}[/tex] is in the set, contradicting the statement that [tex]\frac{k}{2^n}[/tex] is not in the set.
HallsofIvy said:
Suppose [tex]\{\frac{k}{2^n}|k,n\in Z\}[/tex] were not the smallest ring containing [tex]\frac{1}{2}[/tex] and all integers. That is that, the exist some ring, S, that is smaller. Then there must be some integers, k and n, such that [tex]\frac{k}{2^n}[/tex] that is not in S. But, as johng showed, since [tex]\frac{1}{2}[/tex] is in the set, by the multiplication is closed, and induction on n, [tex]\frac{1}{2^n}[/tex] is in the set. And then, since multiplication is closed and the integer k is closed, [tex]\frac{k}{2^n}[/tex] is in the set, contradicting the statement that [tex]\frac{k}{2^n}[/tex] is not in the set.
Well! ... that is a thoroughly convincing proof!
Thanks HallsofIvy ... really helpful ...
Peter
