Calculating RMS Speed of Helium & Oxygen Gas at 260K
  • Thread starter Thread starter ChloeYip
    Gas Rms Speed
The discussion focuses on calculating the root-mean-square (RMS) speed of helium and oxygen gases at a temperature of 260 K using the equation V(rms) = sqrt(3kT/m). Participants clarify the variables involved: k as the Boltzmann constant, T as the temperature, and m as the mass of a molecule. The correct atomic masses for helium (4.0 g/mol) and oxygen (32.0 g/mol for O2) are emphasized, leading to the conclusion that the ratio of RMS speeds can be derived by substituting these values into the equation. The final ratio is determined to be approximately 2.8.
  • Understanding of the ideal gas law and kinetic theory of gases
  • Familiarity with the Boltzmann constant (1.38e-23 J/K)
  • Knowledge of atomic and molar masses of gases
  • Basic algebra for manipulating equations
  • Learn how to derive the RMS speed of different gases using V(rms) = sqrt(3kT/m)
  • Study the significance of atomic and molar masses in gas calculations
  • Explore the application of kinetic theory in real-world gas behavior
  • Investigate the effects of temperature on gas speed and behavior
Students in introductory physics courses, particularly those studying thermodynamics and gas laws, as well as educators seeking to clarify concepts related to gas behavior and calculations.
ChloeYip
(introduction course of university physics)[/B]
A 5.0- liter gas tank holds 1.7 moles of monatomic helium (He) and 1.10 mole of diatomic oxygen
(O2), at a temperature of 260 K. The ATOMIC masses of helium and oxygen are 4.0 g/mol and
16.0 g/mol, respectively. What is the ratio of the root- mean- square (thermal) speed of helium to
that of oxygen?
Answer: C
This is the only equation I found from my book about rms speed of gas, but the variables seems unrelated at all. I have no idea on how to do it.
Please tell me how to deal with it in a more detail way.
Thank you very much.
Unrelated to what? This is actually the correct equation to use.
but how to pluck in the numbers? what should i manipulate to get the required variables?
can you be more specific please?
thanks
The question is
that of oxygen?
Start with that. How do you write that ratio?
What are k, T, and m?
just divide the two which substituded in the equation
of course I know I have to find out all the variables mentioned in the question and the equation in order to answer the question...
but I just have no idea how to figure them out...
can you be more specific? i can't even guess them out... please don't just simply ask me to calculate the answer, because that's exactly my problem for can't getting the answer!
k is Boltzmann constant
t is temperature
m is mass of a molecule
of course i know them, by just substitute them!, but how to find them out?
sqrt(3*1.38e-23*260/1)/sqrt((3*1.38e-23*260/16)=4
but the answer is 2.8
I REALLY have no idea
whats wrong by plucking them in
or if i did something totally in the wrong track
please be more specific on how to do!
like how you figure out the answer
or your steps to calculate it
i can't do anything further based on your question which that seems to be common sense
thank you very much
t is temperature
What are the masses of the molecules? The atomic mass of He is not 1 and the molar mass of the O2 is not 16.
oh yes thanks
  • · Replies 16 ·
18K
