Rocket accelaation at the start of fuel burn
  • Thread starter Thread starter nag
    Fuel Rocket
5 replies · 5K views
nag
Hi Guys this is the problem I am stuck at:
The solid fuel of a 420.0 kg rocket traveling at 18100.0 km/hr is ignited to correct the rocket trajectory in mid-flight to Mars. 5.00 kg of fuel is burnt in 13.0 s. If the exhaust velocity of the fuel, relative to the rocket, is 3650.00 km/hr, what is the acceleration of the rocket (in m/s2) at the start of this burn?
I tried momentum conservation and unable to end up with correct accl of Rocket.
Thanks a lot
Use F = dp/dt = vdm/dt.
The rate of change of momentum of the rocket exhaust gives you the net force on the rocket. So you should be able to determine the acceleration at the beginning of the burn. Why is it (slightly) different at the beginning than at the end of the burn?
AM
Thanks for the help. It is obvious that backward thrust imposes forward force on rocket. In this case as the fuel start to burn I guess rocket gains a little acceleration. Please correct me If I am wrong or missing any.
AM
AM
Hi,
I followed your reply and net force on rocket = (1013.89 m/s)(5/13)kg/s = 389.96N
Since F=ma => a = 389.96 / 420(the initial mass)
Is this right way of doing. Thanks.
nag said:
Hi,
Looks right.
AM
