Rocket Height-Kinematic Question
  • Thread starter Thread starter Chandasouk
    Rocket
The discussion focuses on calculating the maximum height (H) a rocket reaches after exhausting its fuel, given a constant net acceleration (a) and time (t1) until fuel depletion. The initial height (H1) is determined using the formula H1 = 1/2at1^2, while the velocity at fuel exhaustion (Vy1) is Vy1 = at1. The maximum height is derived from the kinematic equation Vf^2 = Vi^2 + 2ad, leading to the final expression for total height as H = 1/2at1^2 + (at1)^2/(2g), correcting earlier dimensional errors in the calculations.
  • Understanding of kinematic equations
  • Knowledge of projectile motion principles
  • Familiarity with acceleration due to gravity (g)
  • Basic algebra for manipulating equations
  • Study the derivation of kinematic equations in physics
  • Learn about projectile motion and its applications
  • Explore the effects of air resistance on rocket flight
  • Investigate advanced topics in dynamics, such as thrust and drag
Students studying physics, particularly those focusing on mechanics and kinematics, as well as educators looking for practical examples of projectile motion in real-world applications.
Chandasouk
A rocket, initially at rest on the ground, accelerates straight upward from rest with constant net acceleration a, until time t1, when the fuel is exhausted.
Find the maximum height H that the rocket reaches (neglecting air resistance).
Express the maximum height in terms of a, t1, and/or g. Note that in this problem, g is a positive number equal to the magnitude of the acceleration due to gravity.
Okay, in this problem, i am pretty much stuck. I only did the hints that Mastering Physics suggested I do to help me solve this problem.
I found the height, H1, above the ground at which the rocket exhausted its fuel
H1=1/2at1^2
I then found the y velocity, Vy1, that the rocket has when the engine runs out of fuel
Vy1=at1
Where do I go from here?
So you got the initial velocity when the rocket runs out of fuel (stops accelerating up) so it is now in free fall. What is the velocity of the rocket when it reaches its max height? Then use the kinematic equation that does not involve time but has displacement in the equation. Essentially the last part of the trip is just like throwing a rock up in the air. You got the velocity upon release, and at max height the velocity is zero.
Once the rocket runs out of fuel it can be treated like any other projectile in freefall. You have its speed when it runs out of fuel, so figure out how much further it rises.
Okay, the equation which pgardn suggested is
Vf^2 = Vi^2 + 2ad
The velocity of the rocket at the max height of it's path is 0m/s
Acceleration during free fall equals -9.81m/s^2
I am assuming the Final Velocity (Vf) is 0m/s, so I set it up like this
(0m/s)^2 = Vi^2 + 2ad
Previously, I found the Y velocity which was Vy1 = at1. I use this as a substitute
(0m/s)^2 = (at1)^2 + 2(-9.81m/s^2)d
0-(at1)^2=-19.62m/s^2*d
-(at1)^2
------------- = D ?
-19.62m/s^2
In terms of a, t1, and/or g, it would be
H = -(at)^2
- 2g
H = -(at)^2
- 2g
That's the additional height the rocket will reach measured from the point where it ran out of fuel. What's the total height above the ground? (And please cancel those minus signs.)
So, previously, I found the height, H1, above the ground at which the rocket exhausted its fuel
H1=1/2at1^2
and also using my last equation
H = (at)^2
2g
The total distance covered by the rocket would equal the sum of these two equations
H=1/2at1^2 + (at1^2/2g) ?
Looks good to me.
Mastering Physics told me this answer was incorrect because
One of your terms has dimensions of time squared, not length.
H1=1/2at1^2
H = (at)^2
2g
It should be
H = 1/2*at12 +1/2 (at2)2/g
You misplaced your parentheses. It should be:
H=1/2at1^2 + (at1)^2/2g
(Sorry for not catching that earlier.)
Use subscripts/superscripts for further clarity:
H=1/2at12 + (at1)2/2g
  • · Replies 47 ·
  • · Replies 53 ·
