Rocket Problem: Determining the amount of fuel burned
The discussion focuses on calculating the initial acceleration of a rocket with a mass of 20,000 kg and a thrust of 3x10^5 N, which is determined to be 5.2 m/s^2. The second part of the problem involves finding the mass of fuel burned when the rocket's acceleration increases to 6 m/s^2 at an altitude of 5,000 m. Participants clarify that the altitude does not impact the calculation, emphasizing that the constant thrust and changing mass are key factors. The understanding is that as fuel is burned, the rocket's mass decreases, leading to increased acceleration. The solution hinges on recognizing that the thrust remains constant while the mass changes, allowing for the calculation of fuel burned.
Ockham
The set up:
A 20,000kg rocket has a motor that generates a thrust of 3x10^5 N.
The problem:
a)What is it's initial Acceleration?
b)At an altitude of 5,000m the rockets acceleration has increased to 6 m/s^2, what mass of fuel has it burned?
Relevant equations:
F = ma
The attempt at a solution:
I found the initial Acceleration to be 5.2 by taking the difference of the thrust and the rockets weight and dividing my the initial mass.
Part two is the one I can't figure out...I don't think the height of the rocket has anything to do with the solution does it?
I agree, the altitude is unnecessary. In fact, it's a bit odd because you could calculate the altitude, and I'll bet it's not 5km exactly.
How do I determine the amount of fuel burned?
Recall how you calculated the initial acceleration. Why does the acceleration increase? What, in your calculation, will have remained constant?
OH...thanks. I get it now. The Thrust is constant the only thing that changes is the mass. Which I can solve for.
Thank you!
Ockham
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
