Rolls Royce permanent magnet thruster questions
The discussion centers on the development and control of a Rolls Royce permanent magnet thruster, specifically focusing on the design and driver requirements for a brushless motor. Participants emphasize the need for an electronic controller to manage rotor speed and commutation, suggesting that brushless motor controller ICs may be necessary, along with additional electronics like power FETs. The main advantage of this motor modality in marine applications is its efficiency and the elimination of the need to seal the drive shaft, enhancing reliability. The conversation encourages further research into motor control techniques and the specific applications of permanent magnet motors.
  • Understanding of brushless motor technology
  • Familiarity with electronic motor controllers
  • Knowledge of power FETs and their applications
  • Basic principles of rotor speed control in electric motors
  • Research brushless motor controller ICs and their specifications
  • Learn about the design and implementation of electronic speed controllers (ESCs)
  • Explore the principles of closed-loop vs. open-loop control systems
  • Investigate the efficiency advantages of permanent magnet motors in marine applications
Engineers, hobbyists, and researchers interested in electric motor design, particularly those focused on marine propulsion systems and efficiency optimization in brushless motors.
Yogi71
Hello,
I am considering an attempt at building or modifying a device inspired by the following, as well as others:
I don't know how I would make a driver for such a thing. Would it need to be software driven for example? Any input to point me in the right direction would be very helpful to me and deeply appreciated.
Thanks!
Welcome to the PF. :smile:
Could you compare and contrast this modality of electric motor with other modalities? What would you say is the main advantage of this modality for the marine propeller application?
What do you mean by that? Are you asking about whether you need some closed-loop control capability to figure out how to time the changing coil currents in the stator? If so, what are your thoughts? When you do more Google searching and reading about this electric motor modality, how are they controlling the speed of the rotor? Do they use feedback, or just drive it open-loop?
Basically it's a large permanent magnet brushless motor. Plenty are used for all sorts of other applications even model aircraft, drones etc
Yes some sort of electronic device is required to control the speed and to commutate the motor. Brushless motor controller ICs are available but I don't know if any support the number of poles you are talking about and you will need additional electronics (eg power FETs) to interface them to the motor windings. Worth looking at their application notes/design guides.
Hi berkman,..." how are they controlling the speed of the rotor?"
I do not yet know how their controller works. I am, at this point, assuming is to be an open loop system, however at least a monitored one. Likely equipped with some emergency controls.
Did you see the good reply by @CWatters ?
Hi berkeman,
The main advantage spoken of in the video was about using less power. More efficiency! As far as "how are they controlling the rotor speed" , at this point I am assuming it is open loop and they slow the firing of the coils. Yet this at some point may need to balance with power to the coils being adjusted.
Not sure exactly how their system works.
Yes I saw that post. I also have pondered that-number of poles- obviously a custom design.
Well, just keep doing your research and reading, and you'll learn a lot more about this electric motor and other modalities of electric motors.
Hint -- For this marine application, not having to seal the drive shaft that drives the propeller is a big advantage for efficiency and reliability. After you have done more reading, you should be able to explain that hint back to us. :smile:
yogi71 said:
some kind of weird attitude...I did enough reading just now. Here's a hint------delete my account! see ya
Hmm, strange. Fun project and lots of great things to learn doing it. Not sure what the problem is, but I'll close this thread for now. PM me if you'd like it re-opened after you've done more reading. Keep on experimenting and learning. :smile:
(Note -- there has been some cleanup in the thread)
The OP is on a 10-day vacation from the PF. He/she can start a new thread showing more of their research and reading when they return, if they want our help. This thread will remain closed.
  • · Replies 16 ·
