Roots lying between the roots of a given equation
  • Thread starter Thread starter utkarshakash
    Roots
9 replies · 3K views
utkarshakash
For what real values of 'a' do the roots of the equation [itex]x^2-2x-(a^2-1)=0[/itex] lie between the roots of the equation [itex]x^2-2(a+1)x+a(a-1)=0[/itex]
The required conditions are
[itex]\large D_1\geq0[/itex]
[itex]\large D_2\geq0[/itex]
[itex]\large R_1<\dfrac{-2}{2}<R_2[/itex]
where
[itex]D_n=[/itex]Discriminant of nth equation and [itex]R_m=[/itex] mth roots of the latter equation
Solving simultaneously the above inequalities and taking intersection
[itex]a\in \left(\frac{-1}{3},0\right)[/itex]
But the correct answer is
[itex]a\in \left(\frac{-1}{4},1\right)[/itex]
haruspex said:
Where does the -2/2 come from? Shouldn't there be an 'a' in there?
Sorry I made a mistake. It must be 2/2 (-b/2a)
haruspex said:
But that's only the average of the roots. You need the condition that each root individually is in that range.
You are not understanding. Its not the average of the roots. Its the x-coordinate at which the minimum value of function occurs.
Express the roots in terms of 'a' first. The non-negativity of the discriminants is not enough.
If you are right, both roots of the first equation lie between or equal to one of the roots of the second equation in case a=-1/3. Is it true?
ehild
ehild
I started by finding roots then substituting them for x in the latter equation and setting them <0. The answer which I get is correct. So, no worries!
Did you get [itex]a\in \left(\frac{-1}{4},1\right)[/itex]? That is the correct answer, I have checked. Why should the roots be negative? Try with a=0.5. Do the roots of the first equation lie between the roots of the second one?
ehild
Yes i got that answer.
