How Does a Rope Fall Through a Hole in Physics?
  • Thread starter Thread starter geoffrey159
    Falling Hole Rope
The discussion centers on the physics problem of a rope of mass M and length l, partially hanging through a hole in a frictionless table. The general solution for the length of the rope through the hole, x(t), is given by the equation x(t) = Ae^{\gamma t} + Be^{-\gamma t}, where γ² = g/l. The participants clarify the relationship between momentum and the forces acting on the rope, ultimately resolving the confusion regarding the vertical momentum of the non-moving portion of the rope. The final insight emphasizes the importance of considering both vertical and horizontal momentum in the analysis.
  • Understanding of classical mechanics, specifically Newton's laws of motion.
  • Familiarity with differential equations and their solutions.
  • Knowledge of momentum concepts in physics.
  • Basic grasp of gravitational forces and their effects on mass.
  • Study the derivation of solutions for second-order differential equations in classical mechanics.
  • Explore the concept of momentum conservation in systems with varying mass.
  • Learn about the effects of gravitational forces on objects in motion.
  • Investigate the role of frictionless surfaces in physics problems.
Students of physics, educators teaching classical mechanics, and anyone interested in understanding the dynamics of systems involving mass and motion.
geoffrey159
A rope of mass M and length l lies on a friction less table, with a short portion, ##l_0## hanging through a hole. Initially the rope is at rest.
a. Find a general solution for x(t), the length of rope through the hole.
(Ans: ##x=Ae^{\gamma t}+Be^{-\gamma t}##, where ##\gamma^2=\frac{g}{l}##)
b. Evaluate the constants A and B so that the initial conditions are satisfied.
Momentum
I don't find this problem hard but I need an explanation.
The solution given solves the general equation ## \ddot x = \gamma ^ 2 x ##. If we multiply by rope mass on the right and on the left, we get
##\frac{M}{l}g x = M \ddot x ##
Since the left part of this equation is equal to net vertical external force, right part is equal to ##\frac{dP}{dt}## in vertical direction. Then the vertical momentum is ## P(t) = M \dot x ##
This is where I have a problem. To me we should have ## P(t) = m(t) \dot x## where ##m(t) = \frac{M}{l} x(t) ## is the hanging mass. The mass ## M - m(t) ## is not moving vertically, so how could it have vertical speed ?
What do you think?
The hole provides the force to change the direction of motion, there is no need to take this into account within the scope of this problem. You simply assume the 90°-turn works, and the force of gravity has to accelerate the whole rope with the same acceleration.
Just using the hanging mass does not work, then nothing could accelerate the part on the table.
I think you're neglecting the buildup in horizontal momentum as well as vertical, whereas the force is as you say just Mxg/l.
Oh thank you! I have neglected the fact that
##\frac{d}{dt}( (M-m(t)) \dot x ) = 0 ##.
So
##M \ddot x = \frac{d}{dt}(m(t) \dot x)= M \gamma^2x ##,
which solves my problem.
Thanks to both of you, and merry Christmas !
So
Meery Christams to you too! Take some time off from physics! :-)
