"Solving Rope Through a Hole Physics Problem
  • Thread starter Thread starter Saitama
    Hole Rope
The discussion focuses on solving a physics problem involving a rope of mass M and length l, with a portion l0 hanging through a hole on a frictionless table. The general solution for the length of the rope through the hole, x(t), is given by the equation x(t) = A e^(γt) + B e^(-γt), where γ^2 = g/l. The constants A and B are determined using initial conditions, resulting in A = B = l0/2, leading to the specific solution x(t) = (1/2)(l0 e^(γt) + l0 e^(-γt)). The discussion also emphasizes the application of Newton's second law to derive the equations governing the motion of the rope.
  • Understanding of Newton's second law of motion
  • Familiarity with differential equations
  • Knowledge of exponential functions and their properties
  • Concept of mass per unit length (λ) in physics
  • Study the derivation of solutions for second-order differential equations
  • Learn about the applications of Newton's laws in dynamic systems
  • Explore the concept of mass distribution in continuous bodies
  • Investigate the behavior of exponential functions in physical systems
Students and educators in physics, particularly those focusing on mechanics, as well as anyone interested in solving dynamic problems involving forces and motion.
Saitama
A rope of mass M and length ##l## lies on a friction less table, with a short portion, ##l_0## hanging through a hole. Initially the rope is at rest.
a. Find a general solution for x(t), the length of rope through the hole.
(Ans: ##x=Ae^{\gamma t}+Be^{-\gamma t}##, where ##\gamma^2=g/l##)
b. Evaluate the constants A and B so that the initial conditions are satisfied.
The forces acting on the rope are weight and tension (T) due to the part of rope on the table. If x is the length of rope hanging, l-x is the length of rope on the table. Let ##\lambda## be the mass per unit length of rope.
Newton's second law for hanging part,
$$\lambda xg-T=\lambda xa$$
Newton's second law for rope on table,
$$T=\lambda (l-x)a$$
From the two equations,
$$a=\frac{gx}{l+2x}$$
I can substitute a=d^2x/dt^2 but Wolfram Alpha gives no solution for this. :confused:
Any help is appreciated. Thanks!
Hi Pranav-Arora. Check your algebra. You made a mistake. It should be la=xg.
Hi Pranav-Arora. Your formulation is correct, but check your algebra. It should be la=xg.
Oh yes, sorry about that. Thanks a lot! :smile:
At t=0, ##x(0)=l_0##, x'(0)=0
##x(0)=A+B=l_0##
Since ##x'(t)=A\gamma e^{\gamma t}-B\gamma e^{-\gamma t}\Rightarrow x'(0)=0=A-B##
Solving the two equations, ##A=B=l_0/2##.
Hence,
$$x(t)=\frac{1}{2}\left(l_0e^{\gamma t}+l_0e^{-\gamma t}\right)$$
Looks good?
It can be solved this way too, by Newton's second law :
F=Ma=\rho g x A
M\frac{d^2x}{dt^2}=\rho g x A
M\frac{d^2x}{dt^2}=\frac{M}{l^3} g x l^2
\frac{d^2x}{dt^2}=\frac{gx}{l}
and the solution of this DE is
x(t)=x=A\cdot exp(\sqrt{\frac{g}{l}}t)+B\cdot exp(-\sqrt{\frac{g}{l}}t)
same as yours...
@janhaa: What are ##\rho## and ##A##? :confused:
\rho is density
and
A: area = l^2
