How Does the Attached Weight Affect the Angular Acceleration of a Rotating Rod?
The discussion focuses on calculating the angular acceleration of a uniform rod with an attached weight, specifically a rod of length L = 6.8 m and mass mrod = 10.6 kg, with a weight of mass M = 5.29 kg attached at one end. The system is released from a 37° angle with no external forces acting on it. Participants clarify that the net torque is derived from the torque exerted by the weight, and the moment of inertia must account for both the rod and the attached mass. The correct formula for total moment of inertia is I = (1/12) * mrod * L^2 + M * (L/2)^2, where the weight's distance from the pivot is L/2.
  • Understanding of rotational dynamics and torque
  • Familiarity with moment of inertia calculations
  • Knowledge of angular acceleration concepts
  • Basic physics principles regarding forces and motion
  • Study the derivation of the moment of inertia for composite systems
  • Learn about torque calculations in rotational motion
  • Explore the relationship between potential energy and angular velocity
  • Investigate the effects of varying mass distribution on angular acceleration
Physics students, educators, and anyone interested in understanding the dynamics of rotating systems, particularly in mechanics and engineering contexts.
huskydc
A uniform rod is pivoted at its center and a small weight of mass M = 5.29 kg is rigidly attached to one end. You may neglect the size of the weight and assume it is located right at the end of the rod.
Suppose that the rod has length L = 6.8 m and mass mrod = 10.6 kg. Suppose also that there are no external forces applied (i.e. Fh = Fv = 0). The system is released from rest at the q = 37° angle. What is the angular acceleration just after it is released?
i did the following;
net torque = I * alpha
find I of the rod+weight system. and net toque, and solve for alpha
but i have a question regarding the force of the rod itself...
i've been told to treat the rod as if all its mass were concentrated at its center of mass. but is that with or without the weight attached to it?
i mean, w/o the weight, the center of mass of the rod is at the axis point., thus no torque on that point.
I assume you mean no forces except that provided by the pivot.
OK. Be sure you calculate the total rotational inertia of the "mass + rod".
For the purpose of caculating the torque produced by the weight of the rod, assume that gravity acts at the center of the uniform rod. But that's for the rod only, not for the extra mass at the end. The weight of that added mass acts right at the end.
Exactly.
Would it be any consolation if I told you that I have no idea as well why you were asked to do that?
They were gently reminding you that the center of mass/gravity of a uniform rod is at its center. :smile: (Although one should know this.)
so would the net torque be just of the torque exerted by mass?
That is correct.
i'm getting myself more confused than ever, the net torque is just of the torque exerted by mass itself. the moment of inertia for rod is (1/12) M L^2. the rod's concentrated mass is still at the axis. so:
total moment of inertia: (1/12) (5.29)(6.8^2) -- mass
do i add (1/12) (10.6)(6.8^2)? if the rod's mass is at the center, does it have moment of inertia...? i guess that's my question
Both the rod and the mass contribute to the moment of inertia of the "rod + mass" system. Add their contributions together to get the total moment of inertia.
The rod's mass is not just at the center! (But the force of gravity acts at the center.) As an extended body, the rod has a moment of inertia given by your formula.
The moment of inertia of a point mass M a distance R from the axis is simply M R^2.
ok, here's my take on total of moment of inertia:
1/12) (5.29)(6.8^2) + (10.6)(3.4^2) ?
and torque of mass:
3.4 * (5.29 * 9.81) sin37 ??
i'm sorry, I'm a microbiology major, I'm really really bad at physics... i really thought i had the right answer, i mean I've figured out the other parts to this problem, just not this one...
I think you have the masses interchanged.
and torque of mass:
Looks OK if the angle is measured from vertical.
so...
I alpha = Torque
(1/12) (10.6)(6.8^2) + (5.29)(3.4^2) alpha = 3.4 * (5.29 * 9.81) sin37
solve for alpha?
(well i already did, b/c I'm getting a little desperate..and its wrong) :frown:
The angle is measured from the horizontal (see my last post), so use cosine instead of sine.
I have a question that piggy backs that problem...what would the angular velocity be whent he rod is vertical?
I know that mgh=1/2Iw^2..but how do I get the potential energy of the rod?
Since the rod's center doesn't move, its potential energy doesn't change.
  • · Replies 19 ·
