Solving Kinetic Energy with Rotation Around Y Axis
The discussion focuses on calculating the kinetic energy of a rod rotating around the y-axis. The user initially describes their understanding of kinetic energy in the xy-plane and expresses confusion about incorporating rotation around the y-axis. They derive the position and velocity components for the center of mass, including a translation component in the z-direction. The user questions the correctness of their approach to the kinetic energy formula, particularly regarding the rotation component. Ultimately, they confirm that they have resolved the problem independently.
Ene Dene
The rod of length 2a swings and it rotates \dot{\phi}[/tex]. Find kinetic energy.<br /> <h2>The Attempt at a Solution</h2><br /> <br /> I know how to find kinetic energy if we have rotation just in xy plane, but I&#039;m having a problem to understand how to do it with rotation around y axis.<br /> <br /> If we have rotation in xy plane:<br /> x_{cm}=asin(\theta)<br /> y_{cm}=acos(\theta)<br /> \dot{x}_{cm}=acos(\theta)\dot{\theta}<br /> \dot{y}_{cm}=-asin(\theta)\dot{\theta}<br /> E_{kin}=\frac{1}{2}m(\dot{x}_{cm}^2+\dot{y}_{cm}^2)+\frac{1}{2}m\cdot\frac{1}{12}(2a)^2\dot{\theta}^2<br /> E_{kin}=\frac{2}{3}m\dot{\theta}^2<br /> <br /> For rotation around y, I assume that we have translation component in z direction, and rotation component.<br /> z_{cm}=asin(\theta)sin(\phi)<br /> Is this correct? (look at the picture)<br /> \dot{z}_{cm}=a(cos(\theta)sin(\phi)\dot{\theta}+cos(\phi)sin(\theta)\dot{\phi})<br /> E_{z}=\frac{1}{2}m\dot{z}_{cm}^2+\frac{1}{2}I_{cm}\dot{\phi}^2.<br /> Rotation part of E_{z} bothers me, maybe I have to multiply it by (lsin(\theta))^2.
Is this ok:
E=\frac{1}{2}(\dot{x}_{cm}^2+\dot{y}_{cm}^2+\dot{z}_{cm}^2)+\frac{1}{2}I_{cm}(\dot{\theta}^2+\dot{\phi}^2)
I have successfully solved the problem by my self, so no need for an answer.
