Rotation by matrix multiplication -- confirmation please
The discussed rotation matrix represents a transformation that swaps the x and z coordinates while leaving y unchanged, effectively rotating the xz-plane by -90 degrees around the y-axis. To obtain the new coordinates after rotation, one should perform matrix multiplication with the original point (x, y, z). The conversation also touches on the need for clarification regarding the term "general point" and the specifics of the problem statement. Additionally, participants discuss the implications of applying the rotation matrix multiple times and the importance of understanding matrix multiplication in this context. Overall, the thread emphasizes the mathematical principles behind rotation matrices and their applications.
Jamie2020
Matrix Rotation
0 1 0
1 0 0
The below matrix represents a rotation.
0 0 -1
0 1 0
1 0 0
Im trying to obtain the general point (x y z) when rotated by the above rotation matrix? So visited https://www.andre-gaschler.com/rotationconverter/ entered the above figures and not sure which entry would be x y z but assume it would be Euler angles (radians) - Could anyone confirm if this would be correct?
Thanks
If you are asking how your coordinates transformed, then you do a matrix multiplication of that with your (x,y,z) column vector and see the result.
Sorry not sure i fully understand what your asking me to do? I thought the result was on that link i provided or are you asking me to a particular area?
Hi,
Not clear what you mean with 'a general point' in the context of (rotation) matrices.
Your matrix swaps x and z and leaves y unchanged. A positive z ends up pointing in a negative x direction.
A little sketch shows that it is a rotation of the xz plane where the x-axis rotates over an angle ##\pi\over 2## towards the z axis.
Likes Zack K
General point is what's written on my paper.
So i assume the answer would be x: 0, y: -1.5707963, z: 0
I can't see your paper from here :smile:
That would be a way to describe the rotation: around the y-axis over ##-{\pi\over 2}## (i.e. in mathematically negative direction: clockwise as seen from the tip of the vector looking towards the origin.
So changing the above link to degrees would give x: 0, y: -90, z: 0. Unfortunately i copied the question as is so i may need to seek further clarification.
The next 2 related questions are
Next bit is to fill the gaps: The rotation matrix represents A rotation of _________ degrees about the ______ axis.
(I think the first gap is -90 and y (axis)
and
Calculate the single rotation matrix that represents two applications of the above rotation matrix
which i would look into next but not sure if that sheds any light on the first question?
Can you post the full and complete poblem statement ? It is still totally unclear to me what exactly is asked of you (and what you have edited or filled in yourself).
Is 'a general point' actually in the problem text ? Or in the preceding chapter in your textbook or course notes ? If so, how is it defined ?
Why would you want to do such a thing ?
Now come the Next bit , apparently litterally copied:
I agree with your reply.
Two approaches:
Do you know how to multiply two matrices ?
If you made a sketch of the first rotation, can you visualize the result of a repeat ?
