Rotational Dynamics of a grinding wheel
The discussion centers on the rotational dynamics of a grinding wheel, which starts with an angular velocity of 28.0 rad/s and a constant angular acceleration of 32.0 rad/s². After 2.20 seconds, the wheel coasts to a stop after turning an additional 350 rad. The total angle turned is 489 rad, the time taken to stop is 9.31 seconds, and the angular acceleration during deceleration is -13.83 rad/s². Key equations used include the equations of motion for rotational dynamics.
  • Understanding of rotational motion concepts
  • Familiarity with angular velocity and angular acceleration
  • Knowledge of kinematic equations for rotational motion
  • Ability to perform calculations involving radians
  • Study the equations of motion for rotational dynamics
  • Learn to apply the formula Vf² = V0² + 2as in rotational contexts
  • Explore the relationship between angular velocity, angular acceleration, and time
  • Practice solving problems involving angular displacement and acceleration
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of rotational dynamics and solving related problems effectively.
Black_Hole???
Ok i am not good with physics and these are some review problems for my test coming up. Please help.
At time t1 = 0 an electric grinding wheel has an angular velocity of 28.0 rad/s. It has a
constant angular acceleration of 32.0 rad/s2. At time t2 = 2.20 s a circuit breaker trips, and the
wheel then turns through another 350 rad as it coasts to a stop at constant angular acceleration.
(i) Through what total angle did the wheel turn between t = 0 and the time it again
stopped?
ANSWER: _______________ Rad
(ii) At what time did the wheel stop?
ANSWER: ________________ ____
(iii) What was the angular acceleration of the wheel as it slowed down?
answers are A1) 489 rad A2) 9.31 sec A3) -13.83 rad/sec^2
Please show work.
Please show work.
First of all please show your attempts. What are relevant equations in rotational motion can be applied in this problem?
Q1(i) Through what total angle did the wheel turn between t = 0 and the time it again
stopped?
My attempt was:
28.0 + 32.0(2.20)^2= 182.88 + 350 = 532.88 rad
The answer was suppose to be 489 Rad.
My attempt was
2.20 + 350/? = ?
I am not sure how i am suppose to find the decrease in acceleration of the angular velocity because i don;t know how long it took and its not given.
I can't solve for this until i know answer B.
28.0 + 32.0(2.20)^2
For this which formula you are using?
Well for that i was using the
Change in distance = initial velocity + 1/2 a t^2
Then i added that to the 350 Rad it said it traveled once the breaker was tripped.
But i realized i forgot the 1/2 in my equation and end up getting 450.44. Which ends up being wrong again.
It should be
Change in distance = initial velocity*t + 1/2 a t^2
Also find the velocity at 2.2 s. This is necessary for the second part.
Ok The velocity at 2.2 sec is =732 rad/s^2
I got that by
Vf=V0 + at
Vf = 28.0 + (32.0)(2.20)
However i realized that I couldn't find an equation that didn't have both time and acceleration involved. What would i do to isolate just time while using the Initial velocity as 732 rad/sec^2 and the final velocity as 0 rad/sec^2. With the total distance traveled to be 350 rads?
It doesn't give me a mass or a frictional force to work with.
This is wrong. Is it the velocity or change in distance or some thing else?
Find out three equations of motion.
wow totally my bad. The answer was 98.4. entered the equation as 2.80+320(2.2)
Now you can use v^2 -u^2 = 2as to find a and t.
OK i got the answers for both B and C. I had the right idea but i keep messing up with entering it into my calculator so i need to check that before i post stuff.
However i got the answer to C first then B.
c) Vf^2 = V0^2 + 2 a s
0 = (98.4)^2 + 2(a)(350)
a=-13.8
B) t = (Vf-V0)/a
t= (98.4-0)/13.8
t= 7.13
T(total) = 2.2 + 7.13 = 9.33
If i were suppose to get it in the order of the test goes how would i go about that.
Thank you for your patience with me and help
v^2 -u^2 = 2as
What is the u^2?
Initial velocity i.e vo.
You can't find the answers in the given order.
  • · Replies 19 ·
