Rotational force of motor + potential gear reduction
The discussion revolves around selecting an appropriate stepper motor for a project involving the tilting of a 15lb display from a flat to an inclined position. Participants explore the concepts of holding torque, gear reduction, and alternative motor types, including worm gear motors and DC motors, as well as the implementation of limit switches for position control.
  • Homework-related
  • One participant is determining the necessary power of a stepper motor to lift a display, considering a moment arm of 5 inches and a required moment of 75 lb-in.
  • Another participant confirms the need for the holding torque of the motor to exceed the required torque, suggesting a safety factor and emphasizing the importance of self-braking torque.
  • A question is raised about whether self-braking torque is a function of holding torque or varies with motor design, highlighting the limited specifications available for stepper motors.
  • A proposal is made to consider a worm gear motor instead of a stepper motor, noting the difficulty in back-driving worm gears and the potential for higher torque ratings.
  • Some participants discuss the advantages of using a worm gear motor, including the ability to power down the motor after positioning the screen and the ease of achieving larger gear reductions.
  • One participant expresses concerns about the need for limit switches, initially planning to rely on step counts with the stepper motor, but acknowledges the necessity of limit switches for safety.
  • Another participant emphasizes the importance of having a "home" switch for defining the zero position before counting steps, suggesting various types of switches compatible with the motor controller.
  • The original poster mentions opting for an Arduino with a motor shield as the controller and recognizes the need for limit switches as a failsafe.
Participants generally agree on the importance of holding torque and the potential benefits of using a worm gear motor. However, there is no consensus on the best approach to implement limit switches or the necessity of using a stepper motor versus a DC motor.
Participants express varying levels of experience with limit switches and motor control, indicating a range of familiarity with the technical aspects of the project. The discussion includes assumptions about torque requirements and motor specifications that may not be fully resolved.
This discussion may be useful for individuals interested in motor selection for mechanical projects, particularly those involving tilting mechanisms, as well as those exploring the integration of limit switches and motor controllers in their designs.
bpm009
I'm trying to determine how powerful of a stepper motor I need for a project. I am attempting to take a display that weighs 15lbs and transition it from laying flat to inclined (approximately 45 degrees) using a stepper motor. I had considered a linear actuator since it would have been an easier build but clearance under the display is an issue and I have more room horizontally.
I haven't done the exact measurements for the lifting arm as I'm not sure if a gear reduction will be needed yet but for example purpose I was thinking of a 5in moment arm from the center of the motor. Even though the display will pivot at the bottom and be supported I figured that when laying flat the motor still has to have enough force to lift the full 15lbs at the 5in displacement for a moment of 75lb-in.
Motors I have looked at talk of a "holding torque" value as what describes them. Did a little research on holding torque but still not 100% understanding the term. These values, for most ideal sized motors, rarely exceeds 250 oz-in or about 15.5lb-in.
Am I right in needing to optimize "holding torque" > moment? In which case if I want to utilize the 15.5lb-in motor I would then need to perform at least a 1:5 gear reduction in order to boost my torque to 77.5lb-in to accommodate the max moment?
Thanks for any input.
You are correct in assuming you'll want the holding torque of the motor/gearbox to be greater than the required torque (plus a safety factor). Ideally, you'll want the motor's "self-braking" torque to be greater than the required torque in the upright position, so that you don't need to power the motor to maintain position of the screen. In that case, the powered torque of the motor will be plenty strong, and you'll be limited by the resting torque of the motor/gearbox combo.
Is a motor's "self-braking" torque a factor of holding torque or is it variable based on motor design/application. When looking at most stepper motors holding torque is typically the only torque value given. Otherwise the specifications are just electrical and physical sizes. Thanks for the self-braking point as I do not want to have the motor constantly powered to resist the load.
I came upon the idea of replacing a stepper and gear reduction with a worm gear motor. I know with worm gears you can't drive the input with the output technically so with my output being the force from the upright screen, would I then be safe in finding a worm gear motor that has a torque rating higher than what my torque requirement is?
I think a worm gear could be a good idea for the reason you're stating- they are very difficult to back-drive so you could position the screen and then power down the motor. It will also be easy to find larger gear reductions when using a worm gear. Will you be using limit switches to detect the position of the screen? If so, it might not be necessary to use a stepper motor at all, and you could instead use a simple DC motor.
That is to be my new problem because with the stepper motor I hadn't planned to use limit switches and base my code off of step counts to provide limits that way. I know I will have to add in limit switches now yes (not quite sure how or best options yet). I had less experience with limit switches and more with coding so that was the reason for stepper over DC motor but I will look into both worm gear and DC motor since I will need limit switches with either.
I appreciate all the info... Civil Engineer attempting to be a Mechanical Engineer here lol. Now it is onward to limit switch options.
With any stepper motor you still need to use some sort of "home" switch to define zero before you can start counting steps from that position. With any motor it's usually best-practice to have switches for at least the travel limits. Any simple switch should work, or even things like optical sensors or flags, but first you should decide what kind of controller you're using and then choose a switch that's compatible with it. So, what kind of controller will you be programming to control the motor?
I've been opting to go with an arduino with motor shield as the controller. I had planned on setting up the motor and designating the "zero" point to base the steps off of after since I didn't plan on moving the gear position after. It would still be smart to go with limit switches as a failsafe I'm sure and I should just do my research on them anyway.
