What is the rotational inertia of a cube when rotated about an edge?
The discussion revolves around determining the rotational inertia of a cube with uniform density when it is rotated about an edge. Participants explore the relevant definitions and mathematical formulations related to rotational inertia in the context of rigid bodies.
  • Participants suggest starting with the definition of rotational inertia and consider using the parallel axis theorem. There are attempts to express the inertia in integral form and discussions about converting variables into Cartesian coordinates.
Several participants have provided insights into the mathematical expressions for rotational inertia, while others seek clarification on specific points, such as the relationship between the inertia of a cube and that of a square. The discussion is ongoing with various interpretations being explored.
Some participants express uncertainty about deriving the rotational inertia from first principles and question the assumptions made regarding the axis of rotation. There is also mention of constraints related to homework rules that may limit the use of external resources.
montreal1775
Does anyone know what the rotational inertia of a cube of uniform density is when it is rotated about an edge? Any help is appreciated!
I suggest you start with the definition of rotational inertia of a rigid body of uniform density.
I=integral(r^2,m)
but then what do I do?
I'd use the parallel axis theorem but I don't know how to find the rotational inertia for a cube about it's center of mass.
You need to be able to derive the equation; you can't look it up (in your textbook, etc.)?
[tex] I = \int r^2 \,dm = \rho \int r^2 \,dV[/tex]
where [itex]\rho[/itex] is the density of the cube (assumed to be uniform).
You can then convert r into a Cartesian equivalent, then split dV into dx, dy, dz and do a triple integral.
I think you should consider the cube from above a plane with greater mass--that is-- 1/12(m)(2L^2). Then parallel axis it.
So would it be [tex] I = \iiint_{0}^{L} x^2+y^2+z^2 \,dxdydz[/tex] where L is the length of a side?
Also, Ja4Coltrane, I don't understand what you mean. Could you please elaborate?
r is the distance from the axis of rotation, not from the centre. If you are rotating about the z axis, then r^2 = x^2 + y^2.
Re Ja4Coltane's post, possibly he means the inertia of the cube about one edge is essentially the same as the inertia of a square about one corner. The thickness contributes to the mass, but it doesn't affect the geometric part of the formula.
So is [tex]I = \rho \iiint_{0}^{L} x^2+y^2+z^2 \,dxdydz[/tex] the rotational inertial of a cube rotated about a corner?
What do you mean by "the rotational inertial about the origin"? I know what rotation inertia about a line is, and I know what the rotation inertia tensor about a point is (and it's got 6 independent components, not just one).
The rotation inertia about the edge defined by (x=0, y=0) is [tex]I = \iiint_{0}^{L} x^2+y^2 \,dxdydz[/tex] That's very similar to the inertia of a square about one corner.
You can use the rotational inertia of a thin plate around the axis perpendicular to the plane of the plate to derive the moment of inertia of a cube around an edge.
Edit: this link may be of some use: http://hypertextbook.com/physics/mechanics/rotational-inertia/" .
  • · Replies 19 ·
  • · Replies 16 ·
