How Do You Calculate Revolutions in Rotational Kinematics?
The problem involves calculating the number of revolutions completed by a flywheel accelerating from 50 rpm to 100 rpm with a constant angular acceleration of 0.5 rad/s² over 20 seconds. Using the rotational kinematics equation, the time to reach 100 rpm is determined to be 100 seconds, but the focus is on the first 20 seconds. The angle rotated during this time is calculated using the equation θ = ωi * t + ½ * α * t², resulting in 1000 radians. Converting radians to revolutions gives approximately 159.15 revolutions completed at t = 20 seconds. This illustrates the application of rotational kinematics in solving motion problems.
djsharpsound
hello, i am new to this board. i was having some problems with this problem?
at t = 0 a flywheel is rotating at 50 rpm. A motor gives it a constant acceleration of 0.5 rad/seconds(squared) until it reaches 100 rpm. The motor is then disconnected. How many revolutions are completed at t = 20 s ?
thanks
Welcome,
This kind of post has to go in "homework help".
In order to get help, you need to show something more than the bare problem.
What have you tried?
where are you stuck?
what equations you expect to be useful?
what happened when you tried them?
for any help
Rotational kinematics deals with the motion of objects that are rotating or moving in a circular path. In this problem, we are given the initial and final angular velocities of a flywheel and asked to find the number of revolutions completed after a certain time.
To solve this problem, we can use the equation:
ωf = ωi + αt
Where ωf is the final angular velocity, ωi is the initial angular velocity, α is the angular acceleration, and t is the time.
Substituting the given values, we get:
100 rpm = 50 rpm + 0.5 rad/s^2 * t
Solving for t, we get:
t = 100 s
This means that after 100 seconds, the flywheel will reach 100 rpm. However, we are asked to find the number of revolutions completed after 20 seconds. To do this, we can use the equation:
θ = ωi * t + ½ * α * t^2
Where θ is the angle rotated, ωi is the initial angular velocity, α is the angular acceleration, and t is the time.
Substituting the values, we get:
θ = 50 rpm * 20 s + ½ * 0.5 rad/s^2 * (20 s)^2
Simplifying, we get:
θ = 1000 rad
To convert this to revolutions, we divide by 2π (since 2π radians is equal to one revolution):
θ = 1000 rad / 2π = 159.15 revolutions
Therefore, at t = 20 seconds, the flywheel will have completed approximately 159.15 revolutions. I hope this explanation helps you understand rotational kinematics better. Let me know if you have any further questions.
If have close pipe system with water inside pressurized at P1= 200 000Pa absolute, density 1000kg/m3, wider pipe diameter=2cm, contraction pipe diameter=1.49cm, that is contraction area ratio A1/A2=1.8 a) If water is stationary(pump OFF) and if I drill a hole anywhere at pipe, water will leak out, because pressure(200kPa) inside is higher than atmospheric pressure (101 325Pa). b)If I turn on pump and water start flowing with with v1=10m/s in A1 wider section, from Bernoulli equation I...
  • · Replies 20 ·
