Rotational kinetic energy of a fly wheel.
The problem involves calculating the rotational kinetic energy of a flywheel given its moment of inertia and the torque applied over a specific time period. The context is within the subject area of rotational dynamics.
  • Participants discuss the need to determine angular velocity and the relationship between torque and angular acceleration. There is mention of an analogous linear problem to aid understanding, and questions arise regarding missing parameters such as the radius of the flywheel and its mass.
Participants are exploring various approaches to the problem, with some offering guidance on relevant equations and analogies between linear and rotational motion. There is recognition of missing information, but no explicit consensus has been reached.
Key constraints include the lack of information about the radius of the flywheel and its mass, which are necessary for calculating acceleration and ultimately the rotational kinetic energy.
leoflindall
The moment of inertia of a fly wheel about it's axis is 20 kg m2. A constant torque of 40 N m is applied to the initially stationary fly wheel. Find it's rotational KE after 3 seconds assuming there is no friction in the system?
KE=[tex]\frac{1}{2}[/tex]I[tex]\omega[/tex]2
I=mr2
a=r[tex]\omega[/tex]2
[tex]\tau[/tex]=Fr , where [tex]\tau[/tex] = torque.
I know I have to work out the angular frequency. Knowing the torque applied to the wheel for a given time I should be able to work out the speed after 3 seconds, but I don't know the radius of the wheel. so I think I need to work out the angular velocity and radius, and then I can work out KE. But I can't see how to do this?
Can anyone give me any advice?
Consider an analogous linear problem: A object of mass M = 20 kg is on a frictionless surface. A constant force of 40 N is applied to the initially stationary mass. Find its kinetic energy after 3 seconds.
What would your procedure be?
Use Newton's second law to work out the acceleration, and then the speed and then use 1/2 m v2 for the energy.
I was looking to do something similar, but I don't have the mass of the fly wheel to determine the acceleration, nor the radius to determine the acceratory force from the torque. Unless I have missed something - I don't do a lot of mechanics!
I know I'm missing something simple here!
Yes, the moment of inertia is the analog of mass for rotational motion. Torque is analogous to force. Angular velocity is analogous to velocity.
You're missing a key equation. The applied torque is proportional to the angular acceleration. T = I a where T is the torque, I is the moment of inertia, and a is the angular acceleration. If you know a and you know how long it is applied, can you find the angular velocity?
I knew I was missing something, with that equation it's easy.
Thank you
Leo
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 33 ·
  • · Replies 21 ·
