Rotational Kinetic Energy of a sphere
The discussion focuses on calculating the kinetic energy of a small sphere rolling inside a hemispherical bowl. The sphere has a radius of 1.6 cm and a mass of 5.2 kg, while the bowl has a radius of 0.82 m. The total kinetic energy at the bottom is derived from the equation mg(R-r) = 1/2mv² + 1/2Iw², where ω = v/r. The key challenge is determining the fraction of kinetic energy associated with rotation about the center of mass.
  • Understanding of rotational dynamics and kinetic energy equations
  • Familiarity with the concepts of moment of inertia (I) and angular velocity (ω)
  • Knowledge of gravitational potential energy and its conversion to kinetic energy
  • Ability to apply kinematic equations in non-linear motion scenarios
  • Study the derivation of the moment of inertia for different shapes, particularly spheres
  • Learn about the relationship between linear and angular velocity in rolling motion
  • Explore the conservation of energy principles in rotational dynamics
  • Investigate the effects of friction in rolling without slipping scenarios
Physics students, educators, and anyone interested in understanding the principles of rotational kinetic energy and dynamics in rolling motion.
kelslee28
A small sphere, with radius 1.6 cm and mass 5.2 kg, rolls without slipping on the inside of a large fixed hemispherical bowl with radius 0.82 m and a vertical axis of symmetry. It starts at the top from rest. What is the kinetic energy of the sphere at the bottom?
What fraction of its kinetic energy at the bottom (in percent) is associated with rotation about an axis through its center of mass?
KE = 1/2 mv2
KErot = 1/2Iw2
Vf2 = Vi2 + 2a(yf-yi)
I found the answer to the first question. My final equation was KE = mg(r2 - 0.5r1). r1 being the ball and r2 is the ramp.
My attempt at the second question was to find the KE and then subtract that from the total KE. When I came up with an equation for KE it was the same exact thing as the equation for my total KE, so I couldn't really subtract them to find the KErot.
I knew that KE = 1/2 mv2 so I used Vf2 = Vi2 + 2a(yf-yi) to find V2 and got that V2 = 2g(r1-0.5r2). Plugging this into the KE equation gives me the same equation [KE= mg(r[SUB]2[/SUB] - 0.5r1)]
PLEASE HELP! Thanks!
you found the total kinetic energy at the bottom. Because the sphere is rolling what is the total kinetic energy equal to?
also note:
\omega=\frac{v}{r}
I can't use the constant acceleration equation because it's not in freefall. What I needed to do, which now I have figured out, is solve for v using the fact that mg(R-r) = 1/2mv^2 + 1/2Iw^2 where w = v/r
Then use that V to solve for the rotational kinetic energy. Divide this by the total kinetic energy and multiply by 100 to get percent.
  • · Replies 21 ·
  • · Replies 33 ·
12K
  • · Replies 19 ·
21K
