How Does a Skater's Rotational Kinetic Energy Change When He Lowers His Arms?
The discussion centers on calculating the rotational kinetic energy of a skater who reduces his moment of inertia from 43 kg/m² to 37 kg/m² while spinning at an angular speed of 17.4 rad/s. The initial rotational kinetic energy was calculated to be 3.53 J using the formula KE = 1/2 I ω². The participant correctly identified that angular speed is denoted as ω and clarified the distinction between angular speed and angular momentum.
  • Understanding of rotational dynamics
  • Familiarity with the concepts of moment of inertia
  • Knowledge of angular velocity and its notation (ω)
  • Proficiency in using the kinetic energy formula for rotational motion
  • Study the relationship between angular momentum and moment of inertia
  • Learn how to derive rotational kinetic energy from first principles
  • Explore the effects of changing moment of inertia on angular velocity
  • Investigate real-world applications of rotational dynamics in sports
Physics students, educators, and anyone interested in the principles of rotational motion and energy conservation in dynamics.
unteng10
A skater spins with an angular speed of 17.4 rad/s with his arms outstretched. He lowers his arms, decreasing his moment of inertia from 43 kg/m^2 to 37 kg/m^2. Calculate his initial and final rotational kinetic energy.
L=I\omega
KE=1/2I\omega^2
Not sure if I am on the right track here, for initial kinetic energy I came up with 3.53 J. I manipulated L=I\omega to get \omega=L/I to find my angular velocity. Then plugged that in the KE=(1/2)(43 kg/m^2)(.405^2) to get 3.53 J. Did I do this correctly?
This is not the angular momentum L, but is is the angular velocity w.
Okay, so the speed would be \omega?
Yes. Angular speed is w.
  • · Replies 21 ·
