Rotational Mechanics -- A solid sphere is rolled on a rough surface
6 replies · 2K views · last reply
Ayesha02
A uniform solid sphere of mass M radius R is placed on a rough surface of given an initial linear velocity ##v_0## and angular velocity ##w_0##, where ##w_0## = ##v_0## /2R. plot the graph of angular speed about the center v/s time t.
##T## = I* alpha , where T= torque, alpha= angular acceleration
and
##w_0(f)## = ##w_0(i)##- alpha*t
I found out the time when rotation ceases to be 4 ##v_0## /5*mew*g, where mew=coefficient of friction of surface but I am unable to plot the graph post that time
Ayesha02 said:
Homework Statement:: A uniform solid sphere of mass M radius R is placed on a rough surface of given an initial linear velocity ##v_0## and angular velocity ##w_0##, where ##w_0## = ##v_0## /2R. plot the graph of angular speed about the center v/s time t.
Relevant Equations:: ##T## = I* alpha , where T= torque, alpha= angular acceleration
and
Is the initial angular velocity lower or greater than the one when the sphere rolls? The friction decreases linear velocity and either increases or decreases angular velocity, till rolling occurs. Determine both as functions of time, Show your work in detail.
ehild said:
The friction decreases linear velocity and increases angular velocity. Determine both as functions of time, Show your work in detail.
I just did
##T## = 2/5 M R^2 * α
which gives α =5μg/ 2R
hence
##w_0(f)## = ##w_0(i)## - α t
i.e 0= ##v_0##/2R - 5μg/ 2R *t
hence i got t=4##v_0##/5μg (time when rotation ceases)
Ayesha02 said:
I just did
hence
You kick a ball. After a short time, does it skid or does it roll?
Skid initially, after some time rolls.
Im assuming the surface is rough
Yes. And what is the angular speed in case of pure rolling with respect to the linear velocity of the CM?
Angular momentum conservation
I got the answer:bow:
