Rotational mechanics. cylinder over a plank
The problem involves a solid cylinder and a plank on a smooth horizontal surface, examining the dynamics when a force is applied to the plank. The context includes concepts from rotational mechanics and friction.
  • Mixed
  • Participants discuss the equations of motion for both the plank and the cylinder, questioning the relationships between forces, tension, and friction. There are attempts to derive the acceleration of the cylinder and verify the correctness of the equations through free body diagrams.
The discussion is active, with participants providing feedback on each other's reasoning and equations. Some guidance has been offered regarding the relationships between the accelerations of the cylinder and the plank, and there is an ongoing exploration of the implications of the equations presented.
Participants are considering the effects of friction and the assumptions regarding the direction of forces acting on the cylinder and the plank. There is uncertainty about the correct application of Newton's laws in this scenario.
vinay.ryder13
a solid cylinder of mass m and radius R and a plank of mass M are placed on a smooth horizontal surface. there is sufficient friction between the cylinder and the plank's surface to prevent sliding of the cylinder. the fixed pulley is smooth. if the plank is pulled with a horizontal force F, the acceleration of center of the cylinder is? (Refer the figure *dia.bmp*),(take tension in the string as T and friction between the cylinder & plank as f).
2. The attempt at a solution
1. started off with the force equation of the plank => F- ( T + f)= Ma ----equation(a)
2. equation of motion of cylinder => T-f = macm -----equation(1)
3. rotational equation of cylinder => fR = Iα
fR = mR2/2 * α
f = macm/2
substituting in equation(1) and solving => T = 3macm/2
we know, acm = a/2 ( doubtful about the requisite)
so substituting the results in equation(a),
F - 2macm= 2Macm
=> acm= F/2(M+m).
but the solution given the referred book is acm = F/3m+M.
have i done some mistake is writing the equations or at some other point? please help! thanks.
Hello there ,
You are doing fine , just a small mistake :smile: is stopping you from getting the right answer .
The accelration of cylinder from grounds point of view would be twice of the accelration of block M.
T+f=2ma
and F+f-T=Ma
try to understand these and then solve again
:cool:
@kushan - but, drawing fbd for plank is giving the eqn F-(f+T)=Ma. That is pricking me. Please can u verify it by an fbd? :)
If F-(f+T)=Ma is correct then the cylinder's eqn would also change.
Vinay ,
The friction is acting along the direction of F on the Cylinder
But [BOLD] according to Newtons law , friction in opp. direction should act on the slab [/BOLD]
Oh...i get it now. Thanks! :)
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 21 ·
