Mentor
- 45,589
- 2,479
No.BobbyBear said:Yes I am assuming that! Shouldn't I?
OK.I'm supposing, as I said, that there is no slipping, so the friction force is a static friction force. The static friction force always equals (in magnitude) the force that wants to provoke movement, until it reaches its maximum possible value (which is the static friction coefficient times the component of the weight normal to the plane of movement).
OK. But that's true for a block but not a wheel.So, if instead of a wheel we had a rectangular block (of equal mass as the wheel), the block would not be moving (assuming an initial state of rest, and assuming, of course, that there's no toppling), because the friction force would be equal to (in magnitude but opposing) the component of gravity parallel to the plane.
No.In both cases (toppling block or rolling wheel), there is no slipping, doesn't this mean (and is necessary for there to be no slipping) that the friction force has equal magnitude to the gravity component parallel to the plane?
In the case of the wheel, you must figure out (using Newton's laws) the friction force necessary to have the wheel not slip. It's not simply equal to the gravity component parallel to the plane.
Set up the torque/force equations for rotation and translation and solve for the needed friction force.
