Rotational Momentum: Calculating Angular Speed After Cockroach Stops
The discussion focuses on calculating the angular speed of a lazy Susan after a cockroach stops running on its rim. The cockroach has a mass of 0.17 kg and runs at a speed of 2.0 m/s on a lazy Susan with a radius of 15 cm and a rotational inertia of 4.9 × 10^−3 kg·m², initially rotating clockwise at 3.9 rad/s. The conservation of angular momentum principle is applied, leading to the equation L_i = L_f, where L_i represents the initial angular momentum and L_f the final angular momentum. The correct calculation of angular speed after the cockroach stops is essential for solving the problem accurately.
  • Understanding of angular momentum and its conservation
  • Familiarity with rotational inertia and its calculation
  • Knowledge of the relationship between linear and angular velocity
  • Basic algebra for solving equations
  • Review the principles of conservation of angular momentum in rotational dynamics
  • Study the relationship between linear speed and angular speed using the formula v = rω
  • Explore examples of rotational motion involving multiple objects
  • Practice problems involving the calculation of angular speed after changes in motion
Students studying physics, particularly those focusing on rotational dynamics, as well as educators looking for examples of angular momentum conservation in real-world scenarios.
JessicaHelena
A Texas cockroach of mass 0.17 kg runs counterclockwise around the rim of a lazy Susan (a circular disk mounted on a vertical axle) that has radius 15 cm,rotational inertia 4.9 ✕ 10^−3 kg · m2, and frictionless bearings. The cockroach's speed (relative to the ground) is 2.0 m/s, and the lazy Susan turns clockwise with angular speed ω0 = 3.9 rad/s. The cockroach finds a bread crumb on the rim and, of course, stops.
(a) What is the angular speed of the lazy Susan after the cockroach stops?
L_i = L_f
L=Iw = mvr
L_i = 4.9 ✕ 10^−3 * 3.9 + .17*2.0*.15
L_f = (4.9 ✕ 10^−3)w_f
But when I solve the equations putting L_i = L_f, the w_f I get is wrong. please help!
The cockroach is running counterclockwise and the table is turning clockwise, yet you added theirangular momentum. Is that right?
And what happened to the mass of the cockroach after it stopped on the turntable?
oh right.
are my equations right otherwise?
  • · Replies 17 ·
