How Does Mass Affect the Direction of Rotational Motion in a Pulley System?
The discussion focuses on the impact of mass on the direction of rotational motion in a pulley system, emphasizing the application of Newton's second law of motion. Participants suggest creating a Free Body Diagram (FBD) to illustrate the forces acting on the system, including the pulley and the two attached masses. The conversation highlights the necessity of formulating equations for both rotational motion of the pulley and translational motion of the masses, and solving these equations simultaneously while considering the kinematic constraints between the masses and the pulley rotation.
  • Understanding of Newton's second law of motion
  • Ability to create Free Body Diagrams (FBD)
  • Knowledge of rotational motion equations
  • Familiarity with kinematic constraints in mechanical systems
  • Study the derivation of equations for rotational motion in pulley systems
  • Learn how to construct and analyze Free Body Diagrams (FBD)
  • Research the relationship between mass distribution and rotational direction
  • Explore simultaneous equation solving techniques in physics problems
This discussion is beneficial for physics students, mechanical engineers, and educators focusing on dynamics and rotational motion in mechanical systems.
Hajar
Hello
Consider a pulley with a rope winded up around it, and two solids attached to the rope from each side. It is intuitive that the solid with the most mass will impose the direction of the rotational motion of the system ( note that the pulley can rotate), but i'd like to know how can we demonstrate that using Newton's second law of motion.
Thank you
Hello Hajar, :welcome:
Well, first we write down this second law of motion in formula form and then we insert the right values for the various variables. Can you make a start ? Use symbols for the masses and make a diagram of the forces that act.
Make the drawing first, in what is called Free Body Diagram form (FBD). This will have three parts to show (1) the pulley, the wrapped rope, (2) the greater mass, and (3) the lesser mass. Add to that the direction of the gravity vector.
Then, with that diagram in front of you, write the equation of rotational motion for the pulley and a translational equation of motion for each mass. Solve these equations simultaneously with the kinematic constraint that must exist between the linear motion of the masses and the rotation of the pulley.
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 21 ·
