Rotational Motion change angular rotational
physgrl
9. A force can change angular rotational if it acts through:
a. the axis of rotation
*b. a lever arm tangential to the direction of rotation
c. a moment arm parallel to the axis of rotation
d. none of these
n/a
I would like to understand why b is the correct answer.
I guess we could start with why it isn't a or c. Angular momentum is changed when Torque is applied. If you apply a force through the axis of rotation, then r is 0. if you apply force through a moment arm parallel to the axis of rotation then torque is also zero since
τ = F x r
|τ| = Frsinσ
since F and r are parallel, the angle is 0, therefore the torque is 0. If you applied it tangentially, then the σ value will be 90 and sinσ will be 1.
physgrl said:
Got it...thanks!
Awesome. youre welcome :smile:
