Rotational motion/conservation HW problem
  • Thread starter Thread starter EndoBendo
    Rotational
The discussion centers on a rotational motion problem involving a vinyl record and a wad of wet putty. The record, with a mass of 0.10 kg and a radius of 0.1 m, initially rotates at an angular speed of 4.7 rad/s and has a rotational inertia of 0.0005 kg*m². Upon the putty, weighing 0.020 kg, sticking to the edge of the record, the total moment of inertia increases to 0.0007 kg*m². The final angular velocity of the system is calculated to be 3.36 rad/s, confirming the conservation of angular momentum.
  • Understanding of angular momentum and its conservation principles
  • Knowledge of moment of inertia calculations for rigid bodies
  • Familiarity with rotational motion equations
  • Basic algebra skills for solving equations
  • Study the concept of angular momentum in closed systems
  • Learn about the moment of inertia for various shapes and their applications
  • Explore the effects of external forces on rotational motion
  • Investigate real-world applications of conservation of angular momentum
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of rotational motion and conservation laws.
EndoBendo
A horizontal vinyl record of mass 0.10 kg and radius 0.1 m rotates freely about a vertical axis through its center with an angular speed of 4.7 rad/s. The rotational inertia of the record about its axis of rotation is 0.0005 kg*m^2. A wad of wet putty of mass 0.020 kg drops vertically onto the record from above and sticks to the edge of the record. What is the angular speed of the record immediately after the putty sticks to it?
Did I do this correctly?? I really struggled to get this lol
Angular momentum = moment of inertia * angular velocity
Moment of inertia of a solid cylinder, like the record = ½ * mass * radius^2
I = ½ * 0.1 * 0.1^2 = 0.0005
Initial angular momentum = 0.0005 * 4.7
Moment of inertia putty = mass * radius^2
I = 0.02 * 0.1^2 = 0.0002
Total moment of inertia after the sticks to the edge of the record = Sum of I’s = 0.0007
Final angular momentum = 0.0007 * final angular velocity
Final angular momentum = Initial angular momentum
0.0007 * final angular velocity = 0.0005 * 4.7
new angular velcoity = 3.36 rad/s
All correct!
many thanks! I just wanted to make sure i wasnt crazy lol
16K
  • · Replies 45 ·
