Rules for curl test applicability
  • Context: Undergrad
  • Thread starter Thread starter mathwizeguy
    Curl Rules Test
The discussion revolves around the applicability of the curl test in vector calculus, specifically in relation to determining whether a differential form is exact. Participants explore the conditions under which the curl test can be applied, including the nature of the curves involved and the implications of the test results.
  • One participant questions whether the curl test applies to a simple closed curve.
  • Another participant clarifies the conditions for a differential form to be exact, citing the relationship between partial derivatives and the curl of the vector field.
  • A participant specifies they are referring to the condition df/dy - dg/dx.
  • There is a further inquiry into whether the implications of the condition relate to the integral around a closed path or the independence of the path for integrals between two points.
  • Participants note that the first implication requires a closed path, while the second does not.
Participants express differing views on the specific implications of the curl test and its applicability, indicating that the discussion remains unresolved regarding the precise conditions and interpretations of the test.
Limitations include the lack of clarity on which specific aspects of the curl test are being referenced and how they relate to the conditions of closed paths versus path independence.
mathwizeguy
trying to remember rules for curl test applicability.
is it just simple closed curve?
is F=-ysin(x)i+cos(x)j able to use the curl test?
It would help if you would cite the "curl test" you are talking about. I think you are referring to the fact that a two variable differential, f(x,y)dx+ g(x,y)dy, is an "exact differential", that is, that there exist F(x,y) such that dF= f(x,y)dx+ g(x,y)dy, if and only if
[tex]\frac{\partial f}{\partial y}= \frac{\partial g}{\partial x}[/tex]
which the same as saying
[tex]curl \vec{f}= \nabla\times\vec{f}= \vec{0}[/tex] where
[tex]\vec{f}= f(x,y)\vec{i}+ g(x,y)\vec{j}[/tex].
It follows from that that the integral of f(x,y)dx+ g(x,y)dy around any closed path is 0 and that the integral from one point to another in the xy-plane is independent of the path. Which of those are you referring to?
i was referring to the df/dy-dg/dx.
Actually, that doesn't answer my question- were you referring to the fact that if df/dy- dg/dx= 0 implies that the integral around a closed path is 0 or to the fact that it implies the integral, from one point to another, is independent of the path.
The first obviously requires a closed path- it says so! The second does not.
