Rutherford Experiment, energy and acceleration.
The discussion revolves around the Rutherford experiment, focusing on the energy and acceleration of alpha particles as they interact with a gold nucleus. Participants explore concepts of electric potential energy and kinetic energy in the context of particle interactions.
  • Participants discuss the conservation of energy and its application to the problem, questioning how to determine the radius of the alpha particles and the relevance of the distance in potential energy calculations. There are inquiries about the forces acting on the alpha particle and the nature of the nucleus.
There is an ongoing exploration of the concepts involved, with participants providing hints and clarifications regarding the use of conservation of energy and Coulomb's law. Some participants suggest focusing on the distance between the alpha particle and the nucleus rather than the radius of the alpha particle itself.
Participants note the need for specific values such as the mass and charge of the alpha particle and the charge of the gold nucleus, while also discussing the implications of assumptions made about forces and energy conservation in the problem.
skg94
If i can make that out its Ep=kq1q2/r where k is coloumbs constant
Im a little confused how do i know the radius of the alpha particles?
I was thinking its conservation of energy, Ep+Ek=Eka then try to solve for a that way, but would Fnet be 0 on this alpha particle?
Right.
Assume it's a point.
That's the way to start, but it's a two-step process; you don't get [itex]a[/itex] directly.
Of course not. If the net force were 0 then there would be no acceleration.
Well, you don't know and don't need their radius. You will need to look up their mass and charge though. The radius being referred to in the potential energy equation is the radial distance of the alpha particle from the center of the gold atom nucleus.
Oh yes, you'll need to know the charge on the gold atom nucleus, too!
Conservation of energy will certainly play a role here. Assuming that the alpha particle heads directly towards a gold nucleus, at what point in its trajectory do you think it'll experience maximum acceleration?
Is the conservation set properly? IF it is, than in the Ep+Ek, what do i use for r?, or is Ep ignorable? Mass of an alpha particle and the charge are, 6.65*10^-27kg and 2e, and gold is what 79 protons, how do i know the charge of that?
It would be at its maximum right before it hits, just as the question suggest wouldn't it be?
What's the charge on one proton? What's the charge due to 79 of them?
The alpha particle is unlikely to have enough energy to enter (hit) the gold nucleus. It'll approach and rebound due to electrostatic repulsion. The thing you'll have to determine is, how close will it get with its given initial KE? What'll be the net force acting on it when it reaches that closest approach?
Oh, since its a positive, that meets a positive atom?, but isn't the nucleus neutral, of any atom? It would be 79+ i would assume. Wouldnt net force just be Force electric, i suppose gravity is too but it is negligible, there was no magnets what so whatever from what i remember from the rutherford experiment.
The nuclei of all atoms (except for antimatter atoms, of course) is positively charged. It's the electrons surrounding the atom that give the atom a net neutral charge. The electric force is the only one you need be concerned with here.
how do i calculate, Fe, i don't see a formula i can use, V=E/d and E=V/d only work for parallel plates right. and i don't know r, the standard Fe=Eq, applies, but both of you said to use conservation of energy, at the moment i can't see to factor it in
The problem statement tells you how to determine potential energy for two charges separated by distance r, and as for force, Coulomb's Law comes to mind...
But you said you don't need to know r, and coulomb's law involves r as well Fe=kq1q2/r^2?
I said you don't need to know the radius of an alpha particle. The radial distance of the alpha particle from the center of the gold nucleus is a different matter -- you will want to calculate a particular value.
Can you give me some sort of a hint?, its not centripetal since it bounces straight back, besides no mag fields, also the is r in the Ep formula, the radius of an alpha particle, or the radius between the two particles?
There is NO alpha particle radius ANYWHERE in this problem. All r's are the distance between charges (alpha particle and nucleus).
Use conservation of energy to determine the closest distance that the alpha particle can approach to the nucleus.
You start with what you know. You know the initial kinetic energy, and the initial potential energy can be set to zero. You know the potential energy due to the electric field at the point of closest approach, and you know what the kinetic energy will be there, too (assume the alpha goes straight in and straight out). Write down the expressions for the initial and final energy, and equate them.
Ek+Ep = Ekf +Epf
1*10^-12 + 0 = 1/2mv^2 + Kq1q2/r ?
Don't use numbers at this stage (except for 0); do everything symbolically. It will be easier to understand.
What is the kinetic energy at the point of closest approach? (This time give a number).
I don't know, 0?
skg94 said:
I don't know, 0?
You surely do know. Throw a ball straight up. What is its kinetic energy at the highest point of its trajectory?
zero right, since at the top as it comes back down in that instant the velocity is zero?
Ek+ 0 = 0 + Ep ? find r through that and use that r in Fe=kq1q2/r^2 ? using charge of alpha particle and charge of gold nucleus, as the other poster stated?
Right. Although you should be stating these things, not asking them.
  • · Replies 38 ·
  • · Replies 19 ·
