S = 12t and S = 490t^2 What do they mean?
  • Thread starter Thread starter Indranil
    Mean
9 replies · 1K views
Indranil
1. The problem statement, all variables, and given/known data
1. S = 12t, where S = displacement ant t = time (in seconds)
2. S = 490t^2, where S = displacement and t = time (in seconds)
What do the two equations mean here? I don't understand what they want to mean here. I am confused.
Could you draw the graphs in support of the two equations above?
2. S = 490t^2 where S = displacement and t = time (in seconds)
What I only know here S = displacement and t = time in seconds
on Phys.org
Think about the equations in terms of x and y (S being x and t being y). Then think about the common forms you are aware of ( y = mx +b, y=ax^2). I think they want you to try to verbally explain the equations. As this happens, this happens. You can easily draw the graphs using existing graphing knowledge which I assume you have.
You can check if you have the graphs right by putting the equations into a graphing calculator (desmos probably).
Still, I don't understand what you mean. Could you make your point easier, please?
It would help if you could give me some context. Are you studying this for physics? math? graphing?
I can help you accordingly, since I would understand what the question wants you to answer.
Do a unit (dimensional) analysis...
For 1.: If t is in seconds and S is in meters what must the units associated with the 12 be?
For 2.: likewise if t is in seconds and S is in meters what are the units associated with the 490?
Sir, I am studying this for physics and math
For 1. It would be 12 seconds and for 2. it would 490 seconds^2
If I am wrong here please correct me
Since you're studying physics as well as math, the equations model a physical situation where something is moving.
In equation 1, each second that elapses, the displacement s changes by 12 units. What sort of motion is implied here? IOW, is the object accelerating, decelerating, or moving at constant speed?
In equation 2, what is the displacement at t = 0 seconds? At t = 1 second? At t = 2 seconds? Is the object acclerating, decelerating, moving at constant speed, not moving at all?
Since you are also studying math, it might be helpful to sketch the graphs of these two equations, with the t-axis horizontal and the s-axis vertical.
No that's not correct.
For 1...
S = 12t
so
12 = S/t
S is in meters and t in seconds so the 12 is actually 12 m/s (meters per second) which makes it a velocity.
In other words eqn 1 is of the form
Displacement = Velocity * time
Can you try something similar for 2.
I think you just have to describe the movement of the object following the path defined by the equation. "As the object displaces by S, time will progress proportionately". Try and think of a description of the particle. Draw a time VS displacement graph and try and follow the particle. Try and visualize.
P.S. No need to call me Sir, I am in high school.
