How Do You Calculate the Safe Work Load of a T Beam?
The discussion focuses on calculating the Safe Work Load (SWL) of a T Beam used in a workshop trestle. Key calculations involve determining the section modulus of the T Beam, allowable stress, and moment. The T Beam is supported at both ends, which requires clarification on whether the support is fixed or pinned. Additionally, the presence of cleats at 1/4 intervals along the length of the beam must be considered in the calculations.
  • Understanding of structural analysis principles
  • Knowledge of section modulus calculations
  • Familiarity with allowable stress theory
  • Basic concepts of moment and load distribution
  • Research the calculation of section modulus for T Beams
  • Learn about allowable stress and its application in structural engineering
  • Study moment calculations and their relevance to beam loading
  • Investigate the implications of cleats on load distribution in beams
Structural engineers, workshop managers, and anyone involved in the design and analysis of load-bearing structures will benefit from this discussion.
Volantis92
Hi Guys,
I want to determine the safe work load (SWL) capacity of a trestle in my workshop. It is a T Beam with width (W), height (h), thickness (t) and length (L). It is welded each end to two legs - what kind of support would this be considered as? Fixed or pin?
Can someone walk me through the calculations to find the SWL that it can endure.
I remember doing something similar in my structural analysis class but cannot find my notes, I believe i have to find the section modulas of the T beam, find allowable stress and find moment? I do not remember exactly the formulas.
There are also cleats 1/4 intervals along length (L), do I consider this in my calcs?
Thank you
Volantis92 said:
Hi Guys,
Thank you
Asking this question on the Internet is not a good approach. You need to talk with a professional engineer in your area, and get them to help you with the calculations. Since it sounds like you are doing something structural, you will likely need to get your local Building Department to sign off on any changes in the structure (or new loads applied to this beam), and your company's insurance company will need to sign off on the changes/new application as well.
Thread is closed.
10K
