- 13,803
- 16,611
...but this design is considerably more efficient than a fan and sail!Dale said:They use metal ducts instead of a sail, but it is the same principle.
“Vector thrust”.DaveC426913 said:Wouldn't it simply be "directed air flow"?
Agree. But I was looking for a general term.Baluncore said:“Vector thrust”.
“Reverse Thrust” brakes on jet aircraft, also VTOL.
Also used on jet boats (water) for steering and reverse.
Did you watch die video starting at 4:00? There is a diagram at 4:34.fleeker said:I'm not sure I understand how the shape of the sail could manage to generate more forward force than the backward force created by sucking the air behind the propeller forward, could you explain?
Are you familiar with momentum conservation? If the balls (initially at rest) end up with negative momentum after bouncing from the board, the boat will get the opposite forward momentum.fleeker said:I imagine if you threw a ball forward there would also be backward movement. Albeit very hard to perceive since it would be so minor.
Yes, the "go faster and create more wind" part omits that at higher speed the apparent wind also comes more from the front.rcgldr said:The "apparent wind" explanation is also mis-leading.
I created a new thread for this and deleted my posts related to apparent wind.A.T. said:Yes, the "go faster and create more wind" part omits that at higher speed the apparent wind also comes more from the front.
But as you note, this not at all what the OP means by "own wind", and the mods already had to delete this derail from this thread once.
Most commercial airliners can do this, but this can only be done at airports where the terminals are built / designed to handle the reverse thrust used to backup.A.T. said:video - "some planes can back up on their own"
Ironically airliners were using thrust reversal even back then. Yet apparently the myth about its impossibility persists even today.Mister T said:Robert Beck Clark wrote an article on this in either TPT or AJP, back in, maybe, the 1980's.
I remember seeing such a device at a science fair a few years ago. The fair itself was outstanding and had many ingenious demonstration experiments for the vistors to play with (tacking with small land sailing vehicles, water containers which could produce bubbles on demand which then would sink a ship, etc.). Given this, I was really surprised to find a device which demonstrated wrong physics among them.Mister T said:At the time one could purchase from one of the scientific supply houses this so-called Newton's Third Law demonstrator that had a fan mounted on a cart, blowing towards the (rigid) sail that is also mounted on the cart. The lecturer could turn on the fan and demonstrate that it indeed didn't propel the cart.
