Sakurai Quantum Mechanics Problem 29 Explained
10 replies · 11K views
mshvn
I have attached a link to the solution set of some questions from sakurai. But I don't understand clearly the solution of question number 5.29.
link: http://www.people.virginia.edu/~7Erdb2k/homework/phys752/quantum.pdf"
how did they found the 4x4 matrix from the spin product, how did they get the complete spectrum etc. etc. it would very helpful, if someone would explain it. It is so much urgent.
I need a explained solution. It is urgent
Link does not appear to be working...
Link corrected here, please click here: http://www.people.virginia.edu/~rdb2k/homework/phys752/quantum.pdf
http://www.people.virginia.edu/~rdb2k/homework/phys752/quantum.pdf"
I need an explanation very urgently. Please help.
Reminding: Question no. 5.29.
Questions: how did they found the 4x4 matrix from the spin product, how did they get the complete spectrum etc. etc. it would very helpful, if someone would explain it. It is so much urgent.
Need explanation of this QM problem
link: http://www.people.virginia.edu/~rdb2k/homework/phys752/quantum.pdf
how did they found the 4x4 matrix from the spin product, why only middle 2x2 matrix of this 4x4 matrix need to diagonalize, how did they get the complete spectrum i.e. |++>, |-->. etc etc after calculating eigenvalues. it would very helpful, if someone would explain it. It is so much urgent.
Please download from the link and see question 5.29. I need a explained solution. It is urgent.
Well I think these may help u better understand...
http://en.wikipedia.org/wiki/Hamiltonian_matrix
http://en.wikipedia.org/wiki/Hamiltonian_(quantum_mechanics )
http://www.nivi.com/papers/hamiltonian.pdf
http://lheawww.gsfc.nasa.gov/users/audley/msctest/node18.html
and sorry if you have already read them..Only the 2x2 middle matrix needs to be diagonalised as the other two values on the boundary are already 1 on the diagonal and the rest are 0's.. for A diagonal matrix only the diagonal elements can have a value (including 0)... other elements need to be 0.
This is the requirement of a diagonal matrix.. It is good to have a diagonal matrix as it helps to simplify the result determination process. And it is valid as any manipulation of the elements of the matrix does not affect the determinant or value of the entire matrix.
Please look into this to understand solving matrices through eigen value manipulation.
http://en.wikipedia.org/wiki/Eigenvalue_algorithm
and look into this for definition of Diagonal matrix..
http://en.wikipedia.org/wiki/Diagonal_matrix
If you have the time .. do glance through this link... It will keep u more informed on the nature and types of matrices...
http://en.wikipedia.org/wiki/Matrix_(mathematics )
Actually, my question is I don't understand the portion indicated in the picture attached. Please see the picture. How they got 4x4 matrix from the previous line, and how they got symmetric and antisymmetric states for those eigenvalues, 1 and -3 respectively and also, how the got the total energy splitting. I am quite weak in these matter. It would be better for me, if you could explain these.
Picture:
Capture by mshvn, on Flickr
for the diagonal matrix they have found the eigen values considering the determinant of the matrix as 0. Eigen values are the ones that when inserted into the matrix result the determinant of the matrix to be 0.
solving the determinant we get as in the picture:: ((-1-L)x(-1-L))-(2*2) = 0;
~= (-1-L)^2 - 4 = 0
hence (-1-L)^2 = 4
Taking sq. root on both sides we get two possible equations;
-1-L = 2 or 1+L=2
hence we obtain 2 possible values of L to be ; L=-3 // L=1
~= (-1-L)^2 - 4 = 0
hence (-1-L)^2 = 4
-1-L = 2 or 1+L=2
I know how to solve eigenvalues. My question is not that. I actually don't understand how they get the 4x4 matrix from the previous line of spin product expression? I mean, they directly wrote the Hamiltonian as 4x4 matrix from the previous line. I don't know how they did that from that spin product?
There is a basis for the space of two particle states which is [tex]\{ |++\rangle, |+-\rangle,|-+\rangle,|--\rangle \}[/tex]. We can choose an index [tex]i[/tex] and label these states as [tex]| i \rangle[/tex] for [tex]i = 1,2,3,4[/tex]. Then the Hamiltonian can be written
[tex]\hat{H} = \sum_{ij} H_{ij} | i \rangle \langle j |.[/tex]
The coefficients [tex]H_{ij}[/tex] are the elements of the matrix corresponding to [tex]\hat{H}[/tex].
