Sand Filter System: Flux & Diameter
The discussion centers on the flux rates of sand filter systems and how they vary with different diameters. Participants reference Darcy's Law as a foundational principle for understanding water flow through sand. There is a request for specific data or tables regarding normal flux rates in sand filters. It is noted that manufacturers typically provide engineering data, including flow rates and expected pressure drops. A filtration velocity of 15m/hr is mentioned as an acceptable standard for performance.
pikkie
Do anybody have any informations on the flux of sand filter system?Varying flux in varying diameter?
Sorry, dude. I have no idea what you're talking about. :redface:
Well, since a sand filter is basicly water flowing throught sand of different grades, did you look up Darcy's Law?
What I actually looking for is, do anybody have any data or tables or figures about the normal flux that run through the sand filter...
If you look up manufacturers of particular filters, they will always provide engineering data on their performance such as flow and expected \Delta P.
15m/hr filtration velocity (superficial) is good enough.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
