Sand Pile Growth Rate: 10 Seconds After Falling
The discussion revolves around the growth rate of a sand pile formed by sand falling onto horizontal ground at a specified rate. Participants explore the mathematical relationships involved in determining the rate at which the radius of the base of the sand pile increases after 10 seconds, focusing on the geometry of a right circular cone and the application of calculus.
  • Homework-related
  • Participants begin by identifying the volume formula for a right circular cone and discuss how to express the height as a function of the radius based on the cone's vertical angle.
  • There is a proposal to relate height and radius using trigonometric functions, with some participants suggesting different approaches to derive the relationship.
  • One participant expresses uncertainty about how to differentiate the volume with respect to time, prompting further clarification from others.
  • Discussion includes the need to find the radius at a specific time (10 seconds) and how to use the volume growth rate to derive this radius.
  • Participants engage in simplifying expressions and applying the chain rule, with some corrections and refinements to earlier claims about derivatives.
  • There is a focus on ensuring the units are consistent, particularly regarding the volume rate being in cubic meters per minute and the time frame of 10 seconds.
Participants generally agree on the mathematical relationships and methods to approach the problem, but there is some uncertainty regarding the application of calculus and the correct interpretation of the volume growth rate over time. No consensus is reached on the final simplification steps, as participants express varying levels of confidence in their calculations.
Limitations include potential misunderstandings about the conversion of time units and the implications of the volume growth rate being expressed in different time frames. Some assumptions about the relationships between variables may not be fully explored.
jiasyuen
Sand falls on to horizontal ground at the rate of $$9m^3$$ per minute and forms a heap in the shape of a right circular cone with vertical angle $$60^{\circ}$$. Show that 10 seconds after the sand begins to fall, the rate at which the radius of the base of the pile is increasing is $$3^{\frac{1}{2}}(\frac{4}{\pi})^{\frac{1}{3}}m$$ per minute.
First, what is the volume of a right circular cone?
$$\frac{1}{3}\pi r^2h$$
Correct, we have:
$$V=\frac{\pi}{3}r^2h$$
Now, given that the angle of repose is $60^{\circ}$, can you express the height $h$ as a function of $r$?
I've no idea. Can you show me? Thanks
Consider the following diagram:
Can you think of a way to relate $h$ and $r$?
$$\tan 30=\frac{r}{h}$$
$$\frac{\sqrt{3}}{3}=\frac{r}{h}$$
$$r=\frac{h}{sqrt{3}}$$
Am I correct? How to proceed?
You are correct, although I would have written:
$$\tan\left(60^{\circ}\right)=\frac{h}{r}$$
$$h=\sqrt{3}r$$
So, substitute this into your formula for the volume of the cone so that you have the volume as a function of $r$ only. The reason we want only $r$ is because we are asked to find $$\d{r}{t}$$.
Then differentiate both sides of the formula with respect to time $t$...what do you get?
$$v=\frac{\sqrt{3}}{3}\pi r^3$$
How to proceed from here? How to 'differentiate both sides of the formula with respect to time t' ?
On the right side, you will need to use the power and chain rules...what do you get?
Do you mean this $$\frac{dv}{dr}=\sqrt{3}\pi r^2$$?
Close, but you have omitted one crucial piece, resulting from the application of the chain rule...you should have:
$$\d{V}{t}=\sqrt{3}\pi r^2\d{r}{t}$$
Now, in the problem statement, you are given information regarding $$\d{V}{t}$$...that is, how fast the volume of the pile of sand is changing with respect to time...can you use this to make a substitution?
$$\frac{dr}{dt}=\frac{9}{\sqrt{3}\pi r^2}$$
How to proceed?
Okay, you need to know the value of $r$ when $t=10$...any ideas on how you can find this?
I've no idea.
If the volume of the pile is increasing at a rate of $9\text{ m}^3$ per second, what is the volume after 10 seconds? Can you use the relationship you have between $V$ and $r$ to then find $r$?
I'm stupid. Stuck at here :(
The volume of the pile can be written as:
$$V(t)=9t$$
Hence:
$$V(10)=9(10)=90$$
And so we must have:
$$90=\frac{\sqrt{3}\pi}{3}r^3$$
So, solve that for $r$, and then plug the result for $r$ into your value of $$\d{r}{t}$$ which is a function of $r$. After you simplify, you should get the desired result. :D
$$\frac{9}{\sqrt{3}\pi\left [ (\frac{90\sqrt{3}}{\pi})^\frac{1}{3} \right ]^2}$$. How to simplify it into $$3^{\frac{1}{2}}(\frac{4}{\pi})^{\frac{1}{3}}m$$ ?
We neglected the fact that the time rate of change of the volume of the pile is given in meters cubed per minute, and we are to find the rate of change after 10 seconds, or 1/6 of a minute, and so we want:
$$V\left(\frac{1}{6}\right)=9\left(\frac{1}{6}\right)=\frac{3}{2}$$
Hence:
$$\frac{3}{2}=\frac{\pi}{\sqrt{3}}r^3\implies r=\left(\frac{3\sqrt{3}}{2\pi}\right)^{\frac{1}{3}}$$
Now see what you get. :D
Teach me how to simplify.
$$\frac{9}{\sqrt{3}\pi \left [ (\frac{3\sqrt{3}}{2\pi})^\frac{1}{3} \right ]^2}$$
$$\frac{9}{\sqrt{3}\pi \left [\left(\dfrac{3\sqrt{3}}{2\pi}\right)^\frac{1}{3} \right ]^2}=\frac{3^2\cdot4^{\frac{1}3{}}}{3^{\frac{3}{2}}\cdot\pi^{\frac{1}{3}}}=3^{\frac{1}{2}}\left(\frac{4}{\pi}\right)^{\frac{1}{3}}$$
35K
