What Does the Scale Show When an Elevator Accelerates Upward?
The discussion focuses on the physics of an elevator accelerating upward and its effect on the reading of a scale. A woman with a mass of 60.0 kg stands on a scale in an elevator with a combined mass of 815 kg. During upward acceleration, the cable exerts a force of 9410 N, resulting in an elevator acceleration of 0.95 m/s². The scale reading, calculated incorrectly as 63.9 kg, should instead reflect the normal force exerted by the scale on the woman, which is influenced by both gravitational force and the acceleration of the elevator.
  • Understanding of Newton's laws of motion, particularly the second law.
  • Familiarity with forces acting on objects in an accelerating frame of reference.
  • Knowledge of gravitational acceleration (g = 9.8 m/s²).
  • Ability to apply free body diagrams to analyze forces.
  • Study the application of Newton's second law in non-inertial reference frames.
  • Learn how to calculate normal force in various scenarios involving acceleration.
  • Explore the concept of apparent weight in accelerating systems.
  • Review the principles of force equilibrium in vertical motion.
Physics students, educators, and anyone interested in understanding the dynamics of forces in accelerating systems, particularly in relation to elevators and scales.
Mohammed17
A woman stands on a scale in a moving elevator. Her mass is 60.0 kg, and the combined mass of the elevator and scale is an additional 815 kg. Starting from rest, the elevator accelerates upward. During the acceleration, the hoisting cable applies a force of 9410 N. What does the scale read during the acceleration?
Mass of woman: 60 kg
Mass of elevator and scale: 815 kg
Starting from rest means Vo = 0 m/s
Force applied is 9410 Newtons in the positive y direction (making up positive y and down negative y)
g = -9.8 m/s^2
Sigma Fy = m*a
Solution:
Two forces acting on the elevator:
Force of gravity against the force of the tension in the cable.
Therefore:
Sigma Fy = m*a
Force of cable on the elevator + Force of gravity = (mass of the woman + mass of the elevator + mass of the scale)*Acceleration of the elevator
We have everything except acceleration of the elevator therefore we can solve for that.
9410 N + (mass of elevator + mass of woman + mass of scale)*(-9.8 m/s^2) = (mass of elevator + mass of woman + mass of scale) * a
9410 N + (815 kg + 60 kg)* (-9.8 m/s^2) = (815 kg + 60 kg)*a
9410 N + (-8575 N) = 875*a
835 N = 875 kg*a
835 N / 875 kg = a
a = 0.95 m/s^2 upwards
Before I solve for the scale's readings, I will assume that it will read a larger mass since it went from rest to an acceleration. The scale will read:
Force felt by the scale = (m)*(acceleration of elevator)
835 N = (m) * ( 0.95)
835/0.95 = m
m = 878.9 kg
Now subtract 815 from it.
878.9 - 815 = 63.9 kg
Is this correct?
- Mohammed.
Mohammed17 said:
g = -9.8 m/s^2Sigma Fy = m*a
835 N = 875 kg*a
835 N / 875 kg = a
This looks OK. However, most textbooks use the symbol ##g## to represent the magnitude of the acceleration due to gravity. Thus, most books take the value of ##g## at the surface of the Earth to be 9.8 m/s2 and not -9.8 m/s2. In this case, if positive direction for ##y## is upward, then the equation ##\sum F_y = M_{\rm sys} \, a_y## would be set up as ##F_{\rm applied} - M_{\rm sys} \, g = M_{\rm sys} \,a##. Here, ##g## is a positive number and the minus sign is indicating that the direction of the force due to gravity is downward.
835/0.95 = m
m = 878.9 kg
Is this correct?
- Mohammed.
This part is incorrect. It is not correct to say
The hint for this part is to apply ##\sum F_y = m a_y## to just the person. ##\sum F_y## will include the force of gravity on the person and the normal force that the scale exerts on the person. The normal force that the scale exerts on the person can then be determined.
What does Newton's 3rd law say about the relation between the force that the scale exerts on the person and the force that the person exerts on the scale?
What is the relation between the force that the person exerts on the scale and the reading of the scale?
The problem statement does not tell us if the scale is calibrated in Newtons or kg.
  • · Replies 22 ·
11K
