Science of Wakes: Low Pressure Region Explained
  • Context: Undergrad
  • Thread starter Thread starter kundukoustav
    Science
The discussion centers on the nature of wakes generated by ships and their association with low-pressure regions. Participants highlight that wakes are undesirable due to their hydrodynamic drag effects, which exceed simple drag force considerations. The conversation also touches on the Kelvin wake pattern, characterized by a V-shaped formation of waves, and mentions the potential of wakefields in advanced particle accelerators. Key references include mathematical explanations by Lord Kelvin and applications in plasma physics.
  • Understanding of hydrodynamics and drag forces
  • Familiarity with the Kelvin wake pattern and its mathematical description
  • Knowledge of plasma physics and wakefield acceleration
  • Basic principles of wave mechanics in fluid dynamics
  • Research the Kelvin wake pattern and its mathematical implications
  • Explore the applications of wakefields in particle accelerators
  • Study hydrodynamic drag and its effects on ship design
  • Investigate the role of wakes in various fluid dynamics scenarios
Marine engineers, physicists, and anyone involved in fluid dynamics or ship design will benefit from this discussion, particularly those interested in the implications of wakes on performance and efficiency.
kundukoustav
we all know wakes are very much undesirable. Also, wakes are of generally very low pressure region. Why is is so? Discussions are welcome
kundukoustav, we all do not know wakes are very much undesirable. Will you please say why they are?
I see plenty of ship wakes while exploring on Google Earth. (Try in the Suez Canal, for example...there are some great ship wake examples to see.) I can't understand why you say they are "of generally very low pressure region". How can that be? Will you please explain that for me also? Thank you.
Bobbywhy
Consider a car moving! check the drag force (pressure drag) of air on the car! You will get the idea!
The wake behind a moving ship is more than hydrodynamic drag. That's not a sufficient description of the wake-forming mechanism.
This is not always true. Wakes generated in a plasma are now being used to generate high gradients as part of a research for the next generation of particle accelerators.
http://physicsworld.com/cws/article...a-wakefield-turbocharges-particle-accelerator
Other groups are using wakefields generated in metallic and dielectric structures.
Zz.
A wake (from a boat and probably from any other source too) is surely a wave. The energy in it takes a long time to dispel because, once it has settled down, it has a straight wave front. Until it comes to a discontinuity (shallow water) it hardly disperses at all. It represents a huge proportion of the ship's engine output, I think.
kundukoustav, You must have noticed by now there are several kinds of wakes. The wakefield accelerator has great promise. From your mistaken comparison with aerodynamic drag on a car I am assuming you are referring to boat or ship wakes.
"Wake pattern of a boat:
Waterfowls and boats moving across the surface of water produce a wake pattern, first explained mathematically by Lord Kelvin and known today as the Kelvin wake pattern. This pattern consists of two wake lines that form the arms of a V, with the source of the wake at the point. Each wake line is offset from the path of the wake source by around 19° and is made up with feathery wavelets that are angled at roughly 53° to the path. The interior of the V is filled with transverse curved waves, each of which is an arc of a circle centered at a point lying on the path at a distance twice that of the arc to the wake source."
http://en.wikipedia.org/wiki/Wake
For a more detailed analysis of steel ship wakes see:
http://www.steelnavy.com/WavePatterns.htm
  • · Replies 40 ·
  • · Replies 76 ·
12K
  • · Replies 27 ·
