Searching for problems in fiber, splicing or connector
  • Thread starter Thread starter mimonici
    Fiber
The discussion centers on troubleshooting issues with a fiber laser system that previously produced good results but now shows worse performance. The user has tried replacing fiber components and connectors without success. Suggestions include systematically testing each component and configuration to identify the problem, as well as considering factors like photo-darkening and damage to end-facets. The user has clarified their setup includes various optical components and has attempted to adjust the optical spectrum analyzer settings, but still faces challenges in achieving consistent results. The need for significant data and effective troubleshooting methods is emphasized to resolve the ongoing issues.
mimonici
I've made fiber laser system. Previously, there's no problem in my set up and achieved good result.
Further, when I want to repeat that experiment with similar set up, spectrum shows quite worse than previous.
I'd try to check,change certain new fiber components,connectors but it still worse.
How can I improve that, to find out what actually the probable problem?
Hi
You don't include any details of your system so I don't think anyone can help you much, yet. There are two approaches to 'something not working'. You can replace one component at a time (why car repairs are so expensive) or examine each piece in turn, testing the other pieces in alternative configurations. If you have any test equipment, then you have to sit down and use it to eliminate one element at a time until you can zero in on the cause of the problem.
A very generic answer to a very generic question.
Some things to think about;
Photo-darkening - prolific at short wavelengths.
Damage to the end-facets - prolific at high powers.
As sophiecentaur said, it is difficult to guess with limited details of the problem.
Claude.
Thank u for concern to both of u gentlemen. Alright, now I'll make it clear. I am configuring a set up of fiber laser. In the configuration contains optical components; 90:10 couplers, single mode fiber, erbium-doped fiber(s), optical circulators, laser diode(s), wavelength-division multiplexing(s), 3dB coupler, Polarization Controller and Polarization Maintaining Fiber. Certain of the components i'd spliced by using optical splicer and certain were connected with connector. I'd analyze the output by optical spectrum analyzer(OSA).
This configuration I've made to achieve broad wavelength range of spectrum of the fiber laser as 11+nm wavelength. I've got the desired result previously but unable to repeat day by day. So, after discussed, I think the desired obtained result was not clear enough because of wrong span and resolution set from the OSA. Thats why I repeat the experiment to obtain same result with improved span and resolution of the OSA. Consequently, it failed. I really need the significant data.. Any suggestion to detect what are actually the problems of my set up?
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
