Second derivative test fails for y=(x^2-1)^4 at x=±1
2 replies · 3K views
Dramacon
I'd always used the 2nd derivative test for the nature of stationary points. But I came across this equation in one of my exercises, for which the test doesn't seem to work at all.
Find the stationary points of: y=(x^2-1)4, stating the nature of each.
Using normal calc: the stationary points are at (-1,0), (0,1) and (1,0)
Although the double derivative works for when x=0, (local max)
When I sub in the values x=1 or x=-1, the value I end up with is 0: suggesting that these points are stationary points of inflection, when they are not (they're actually local minima).
Please help. :)
Hi Dramacon! :smile:
From http://en.wikipedia.org/wiki/Inflection_point#A_necessary_but_not_sufficient_condition :wink: …
A necessary but not sufficient condition
If x is an inflection point for f then the second derivative, f″(x), is equal to zero if it exists, but this condition does not provide a sufficient definition of a point of inflection. One also needs the lowest-order (above the second) non-zero derivative to be of odd order (third, fifth, etc.). If the lowest-order non-zero derivative is of even order, the point is not a point of inflection. (An example of such a function is y = x4).​
