Seeking Guidance on Working Through Tank Problem with Multiple Tanks
40 replies · 7K views · last reply
Jason-Li said:
I feel like I need a time aspect on the Right hand side of this formula?
To avoid confusion: the expression time aspect does not mean anything to me. Can you explain what you mean ?
Going back to post #21: eight variables, 5 knowns, 3 unknowns and 3 equations. I see I have given away the recipe already but you started to cook up something different.
Let me be more precise:
1. Work around ##(1)## and ##(2)## to get ##Q## as a function of the driving force ##h_1-h_2##. Don't use anything from ##(3)##.
2. Substitute that ##\ Q(h_1-h_2)\ ## in ##(3)##. We now have one first order differential equation (DE) in terms of one time-dependent variable ##h_1-h_2## and the form is like ##\ y'= -ky\ ## with ##k>0##
##Q## has now been eliminated and can be forgotten. If we need it, we can dig up ##(3)## or one of the other two.
3. Invent some initial condition ##\;h_{1,0}, h_{2,0}\;## and and some parameter values (the 5 constants) and solve the DE . Make some plots.
4. See if it all also works if ##\;h_{1,0}< h_{2,0}\;## :smile:
BvU said:
Think again.
For the form of y'=-ky k represents a constant, so k would be DG/rf and the y value would be the driving force of h1-h2?
BvU said:
What is that ? Or do I have to ask: what are those ? Can you spell it out for me ?When does it (they?) become zero ?
The difference in the hieght gives the driving force e.g. when h1>h2 the pressure in the first tank will cause flow to try and equalise the tanks. h1-h2 will be zero when the tanks are at equilibrium.
I thought before I would need a value of "t" on the right hand side I could hypothetically substitute in.
BvU said:
1. Work around (1) and (2) to get Q as a function of the driving force h1−h2. Don't use anything from (3).
Not going to lie I am unsure of how to do this without touching equation 3, I've done some reading and youtube video watching but can't quite find what I need, e.g. (this uses a state-space model).
I can't equate them as I will lose the Q variable I need to create \ Q(h_1-h_2)\ I could add them together to create
$$2Q = A_2{dh_2\over dt}-A_1{dh_1\over dt}$$
However even if i rearrange this I don't see how I can get to the $$\ Q(h_1-h_2)\$$ ?
Sorry to keep bothering you I feel like we are near a turning point though!
I have spoken to someone else and they advised this:
But we are already at this point in post 21
Task at hand:
I'm baffled that you go searching instead of doing some simple math. I can't provide more guidance without robbing you of the exercise, but that can't be helped. See below for what I meant. I am even more baffled that you go so far out in searching, instead of looking in the other thread that you yourself mentioned in post #3 !
Note: I don't mean to be critical or anything, the subject matter is obviously new to you and you need to get acquainted with it. So:What I meant is: ##\ \ ##You have $$
\begin {align*}
Q &= - A_1\,{d\, h_1\over dt} \tag{1}\\ \ \\
Q & = \phantom{-} A_2\,{d \,h_2\over dt} \tag{2}\\ \ \\
\end{align*}$$ and you want something in terms of ##h_1-h_2##.
Perhaps it is a good idea to divide left and right side of ##(1)## by ##A_1## and divide left and right side of ##(2)## by ##A_2##. You then have expressions for ##\ \displaystyle{dh_1\over dt}## and for ##\ \displaystyle {dh_2\over dt}##. What do you get for ## \ \displaystyle{d(h_1-h_2)\over dt \ \ }## ?
So ##\ \displaystyle{Q=\ ...\ {d(h_1-h_2)\over dt }}\ \ ## o_O .
Note: the ... part is constant and will go into the ##k## and that means​
Jason-Li said:
so k would be DG/rf​
Is not completely correct.​
---- also: try to be consistent in your notation: Dg/Rf​
So far step 1.
@BvU
Apologies I seem to be losing my mind... the only explanation for not seeing thiso_O No offense taken!
So working (1) which you have kindly done.
\begin {align*}
{Q\over A_1}= -{d\, h_1\over dt} \tag{1}\\ \ \\
{Q\over A_2} ={d \,h_2\over dt} \tag{2}\\ \ \\
{Q\over A_1}+{Q\over A_2} =-{d\, h_1\over dt}+{d \,h_2\over dt} \tag{1&2}\\ \ \\
-{Q\over A_1}-{Q\over A_2} ={d\, h_1\over dt}-{d \,h_2\over dt} \tag{1&2 x-1}\\ \ \\
-{Q\over A_1}-{Q\over A_2} ={d\,(h_1-h_2)\over dt} \\ \ \\
Q(-{1\over A_1}-{1\over A_2})=-{d\,(h_1-h_2)\over dt} \\ \ \\
Q= {d\,(h_1-h_2)\over dt} / (-{1\over A_1}-{1\over A_2})\\ \ \\
Q= {d\,(h_1-h_2)\over dt} / ({-A_1-A_2\over A_1A_2})\\ \ \\
Q= -{A_1A_2\over A_1+A_2} * {d\,(h_1-h_2)\over dt} \\ \ \\
\end{align*}
Does this look correct now? with the k factor being:
If so for step 2:
$$-{A_1A_2\over A_1+A_2} * {d\,(h_1-h_2)\over dt} = {D\,g\over R_f}\,(h_1-h_2)$$
So would I work this through until I have:
$${dh_2\over dt}=...$$
Jason-Li said:
So would I work this through until I have: ##\ \displaystyle {dh_2\over dt}##
That is not the idea for this exercise, no. You now have $$ {d\,(h_1-h_2)\over dt} =
-{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)$$Which is of the form ##\ y'= -k\,y\ ##, so easily solved if the initial ##h_{1,0}## and ##h_{2,0}## are given .
When I re-read your post #3 I understand where your interest in ##h_2## comes from. Well, at least now you have the answer for part (b) :wink: .
For part (a): Do you see a path to express ##h_2## when ##h_{1,0}## and ##h_{2,0}## are given and ##h_1-h_2## is known as a function of time ?
For Part (b) I can basically follow the other thread as we are at a point now that I can bring the equation to meet the equation here although I don't really see how they did the step shown by the red arrow
Handwritten derivation of a two-tank drainage problem: a differential equation for the height difference, its integration to x = x0 e^(-t/tau), and a boxed final expression for dh_out/dt with a red arrow pointing to the exponential step.
For part (a) could I integrate the left hand side between limits of h1-h2 and h1,0-h2,0 to give:
$$(h_1-h_2)-(h_{1,0}-h_{2,0}) = -{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)t$$
$$-h_2 = -{D\,g\over R_f} {A_1+A_2\over A_1 A_2} \,(h_1-h_2)t+(h_{1,0}-h_{2,0})-h_1$$
Along the right lines here?
  • Handwritten derivation of a two-tank drainage relation: d(h1-h2)/dt = -(1/R)(1/A1 + 1/A2)(h1-h2) rearranged to dx/dt = -(g/R)(A1+A2)/(A1A2) x, integrated to x = x0 e^(-t/tau), leading to dh2/dt = -(A1 dh1/dt)/(A1+A2)-type expressions and a boxed result dh2/dt = (A1/(A1+A2))(x0/tau)e^(-t/tau), where x0 = h1,0 - h2,0.
  • Handwritten derivation of a two-tank drainage relation: d(h1-h2)/dt set equal to a term with A1, A2 and R, reduced to dx/dt = -(g/R)(1/A1 + 1/A2)x, then integrated to x = x0 e^(-t/tau), leading to dh2/dt expression with x0 = h1,0 - h2,0.
$$\Bigl .\ln x\,\Bigr |^x_{x_0} = \ln x -\ln x_0$$
I don't think so !
What left hand side ? The ##\displaystyle{dx\over x}\ ## integral was done and gave ## \ln x -\ln x_0## !
How about 'stealing' the answer from the other thread ? Or don't you like it :rolleyes: ?
I don't think so !
Thanks for that explanation.
So their final answer of
Handwritten derivation: d h_out/dt = (A_T0 / (A_T0 + A_out)) (x_0 / t) e^(-t/τ), boxed, where x_0 = h_in,0 - h_out,0.
is suitable for part (a)?
Is their method of identifying the time constant of 63.2% also suitable?
Jason-Li said:
So their final answer of ... is suitable for part (a)?
What do you think? Can you find fault?
I don't think I can see a mistake with the formula however going back to post #35 where you said to find h2, the attached image in #38 isn't expressly looking for h2 rather dh2/dt but this is likely still correct. Think I have a lot of doubts at the moment, apologies.
In terms of part b if my "time is over tau then the time constant should be 63.2% in line with first order systems
I see what you mean. But I suppose an extra integration is unavoidable. One way to look at it: ##h_2-h_1## (and thereby ##Q##) follows from solving the differential equation & initial conditions. Subsequently ##h_2## follows from ##\ \displaystyle{ \int {dQ\over dt}}##.
It's always good to be critical :smile: . And check things.
