Selecting the correct power source for a Cockroft-Walton Multiplier
The discussion centers on selecting a power source for a Cockroft-Walton voltage multiplier capable of varying DC voltage from 0-6kV and regulated current up to 20mA. The user has acquired .001uF capacitors and diodes rated for 20kV and 30mA, but seeks clarification on connecting a 120VAC source to the multiplier. The consensus emphasizes the dangers of working with high voltage and the necessity of consulting an experienced electrical engineer for safe implementation.
  • Understanding of Cockroft-Walton voltage multiplier circuits
  • Knowledge of high voltage safety protocols
  • Familiarity with AC to DC conversion using diodes
  • Experience with voltage regulation techniques
  • Research high voltage safety measures for DIY projects
  • Learn about AC to DC conversion methods in power supplies
  • Investigate voltage regulation techniques for high voltage applications
  • Explore the design and operation of Cockroft-Walton multipliers
Electrical engineers, hobbyists working on high voltage projects, and anyone interested in building or understanding voltage multipliers safely.
Cu_extractor
Hello. I'm in the process of selecting materials for a voltage multiplier. I need to be able to vary a DC voltage source from 0-6kV, possibly with a regulated current up to 20mA.
http://www.diyphysics.com/2012/02/0...upply-with-neat-trick-for-switching-polarity/
I bought .001uF capacitors rated at 20kV & 30mA. I bought diodes rated @ 20kV & 30mA.
I'm trying to follow the schematic for the above link but I'm a little confused as to getting 120VAC from my wall to the voltage multiplier. It appears the diodes should cause any AC signal put into this device to convert to a multiplied DC voltage output.
I'm not sure what power source I should connect to the multiplier. Voltage drives current, so would a regulated AC voltage source to the multiplier work without damaging any components? Also, is it possible to regulate the current from 0-20mA?
Thank you
Sorry, we will not be able to help you on this. It is way too dangerous for you to be doing with your limited background and experience. Please try to find an experienced EE near you who is willing to help you in person with this project. There are a number of things you need to do right when dealing with AC Mains projects, and more things you need to do right when working with HV.
Thread is closed.
  • · Replies 24 ·
28K
  • · Replies 17 ·
