Self-Diffusion, two versions of mean square displacement
1 reply · 3K views
Derivator
Dear all,
in self diffusion theory you can see in different books, different definitions of the mean square displacement:
[itex]<r(t)^2> = \frac{1}{N} \int d\vec{r} \ \vec{r}(t)^2 c( \vec{r} ,t)[/itex]
where c(r,t) is the particle concentration and N the number of particles.
or
[itex]<r(t)^2> = \frac{1}{N}\sum_i^N \vec{r}_i(t)^2[/itex]
In all theoretical derivations, only the integral version is used whereas in practical / applied treatements of self diffusion, the sum version is used. This is why I assume, the sum version is an approximation to the integral version. But I don't see it.
derivator
Edit:
See for example:
the sum version (formula 2.2): http://ocw.mit.edu/courses/nuclear-...of-transport-fall-2003/lecture-notes/lec2.pdf
the integral version (formula 12.4): http://books.google.de/books?id=PTO...sion mean square&pg=PA124#v=onepage&q&f=false
This is known as the test-particle method. The idea behind this method is to describe the diffusion of the particles, e.g., in an suspension by the motion of test particles under the influence of a friction force (the average force from many collisions of the fluid molecules of with the particle) and a fluctuating random force. This is the Langevin equation. This you do many times in a Monte Carlo simulation which gives trajectories [itex](\vec{\xi}(t),\vec{\pi}(t))[/itex] in phase space. The concentration is then given by the test-particle ansatz,
[tex]c(t,\vec{x},\vec{p})=\frac{N}{N_e} \sum_{i=1}^{N_e} \delta^{(3)}[\vec{x}-\vec{\xi}_i(t)] \delta^{(3)}[\vec{p}-\vec{\pi}_i(t)],[/tex]
where [itex]N[/itex] is the number of suspended particles and [itex]N_e[/itex] is the number of test particles, i.e., the ensemble size.
Of course the concentration as function of space alone is given by
[tex]c(t,\vec{x})=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{p} c(t,\vec{x},\vec{p}).[/tex]
Now, if you plug in the test-particle ansatz for [itex]c(t,\vec{x})[/itex] into the equation for average quantities, you get your second equation.
The Monte Carlo statistics given by the Langevin equation, is by the way equivalent to the Fokker-Planck equation (or diffusion equation) for the concentration, which is a deterministic partial differential equation (transport equation).
The whole trick of test particles is that you can put them on a computer to solve the transport equation.
