Semi circular prism and light rays
The discussion focuses on the behavior of light rays passing through a semi-circular prism, specifically addressing the question of which rays refract only once. It is established that rays hitting the center of the flat surface will refract at an angle of 0 degrees, while rays not hitting the center will refract multiple times due to their angles of incidence. The key principle applied is Snell's Law, which governs the refraction of light at the interface of different media.
  • Understanding of Snell's Law
  • Knowledge of light refraction principles
  • Familiarity with the geometry of semi-circular prisms
  • Basic concepts of angles of incidence and refraction
  • Study the application of Snell's Law in various optical media
  • Explore the geometry of prisms and their effect on light paths
  • Investigate the conditions under which light refracts only once
  • Examine practical experiments demonstrating light refraction through prisms
Students studying optics, physics educators, and anyone interested in the principles of light behavior in prisms.
hallowon
So anyway in the diagram of my book there is a ray hitting the centre in the flat part of a semi circular prism. The question in the book states "Ignoring partial reflection, we know that each ray will pass through the flat surface and then pass through the curved surface, Which of the rays refract only once? Explain" I also do not get why it refracts more than once if the light rays do not hit the centre.
Snell's law
I know from the centre to the edge it is the radius of the semi circular prism. When the light refracts from the centre onto the edge i know that the normal is perpendicular to that point and the angle of refraction = 0.
Snell's law
Welcome to PF :smile:
Something is not clear from what you wrote. Is there just a single ray in the figure, hitting the center of the flat side? Or are there more rays (and if yes, please describe their path, i.e. where and at what angle are they incident on the prism?)
It sounds like they are defining "to refract" as "to pass through a surface and exit at an angle different than the incident angle". In other words, if a ray passes through a surface without changing its angle, it is not considered to refract there.
If so, you'll need to think about under what condition a ray does not change its angle when passing through a surface.
