Semi-empirical mass formula: most stable isobar for odd A
The discussion focuses on the application of the Semi-empirical Mass Formula to determine the most stable isobar for odd atomic mass number A. The key equation used is B(A,Z) = aV A − aS A2/3 − aCZ2A-1/3 − aA(Z − N)2/A, where the derivative dB/dZ = 0 is computed to find the maximum binding energy. A critical point raised is the need to account for the factor of one-half in the calculations, which arises from the treatment of the neutron to proton ratio N/Z. The error identified involves incorrectly treating N as constant during differentiation.
  • Understanding of the Semi-empirical Mass Formula
  • Knowledge of binding energy calculations in nuclear physics
  • Familiarity with differentiation techniques in calculus
  • Concept of neutron to proton ratio in nuclear stability
  • Study the derivation of the Semi-empirical Mass Formula in detail
  • Learn about the significance of pairing terms in nuclear stability
  • Explore the implications of neutron to proton ratios on nuclear binding energy
  • Investigate common errors in calculus related to variable differentiation
This discussion is beneficial for physics students, nuclear physicists, and researchers focusing on nuclear stability and binding energy calculations.
Bobjovi
Using the Semi-empirical Mass Formula show that for fixed odd atomic mass
number, A, the most stable isobar has a neutron to proton ratio given by
N/Z = 1 + aCA2/3/(2aA)
B(A,Z) = aV A − aS A2/3 − aCZ2A-1/3 − aA(Z − N)2/A + pairing term
I computed dB/dZ = 0 because the most stable means the one with the maximum binding energy. I get the formula but missing the factor of a half. The fact A is odd means that we don't have a pairing term.
My question is where does the half come from? What am I doing wrong?
We would need to see your computation of dB/dZ to find your mistake. One thing to keep in mind, you cannot treat N as constant while taking the derivative with respect to Z.
I think your asymmetric Energy term is an error in the above mentioned B.E formula ..
replace (Z-N) By (N-Z)
  • · Replies 23 ·
