Semi Latus Rectum Proof - b^2/a
  • Thread starter Thread starter sportsguy3675
    Proof
The length of the semi latus rectum of an ellipse is definitively proven to be equal to b²/a. This conclusion is derived from the ellipse equation x²/a² + y²/b² = 1, where the semi-latus rectum is defined as the line perpendicular to the major axis through one of the foci. By substituting x = ae into the ellipse equation and manipulating the resulting expressions, the relationship between the semi-latus rectum, the semi-major axis (a), and the semi-minor axis (b) is established. The proof utilizes the eccentricity (e) of the ellipse, leading to the final expression l = b²/a.
  • Understanding of ellipse equations, specifically x²/a² + y²/b² = 1
  • Knowledge of geometric properties of ellipses, including foci and axes
  • Familiarity with the concept of eccentricity (e) in conic sections
  • Basic algebraic manipulation skills for solving equations
  • Study the derivation of the eccentricity of an ellipse, e = c/a
  • Explore the geometric properties of ellipses, including foci and directrices
  • Learn about the applications of the semi-latus rectum in physics and engineering
  • Investigate other conic sections and their properties, such as parabolas and hyperbolas
Students of mathematics, particularly those studying conic sections, geometry enthusiasts, and educators looking to enhance their understanding of ellipse properties and proofs.
sportsguy3675
I need to prove that the length of the semi latus rectum = b^2/a
I am assuming that you make some sort of a triangle within the ellipse to prove this, can someone point out which one it is?
:confused: Why has no one responded? Doesn't anyone know how to do this?
The equation for an ellipse relation is:
\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1
If you draw the ellipse with a string fixed at each foci, the length of the string is the major axis, 2a. The minor axis (x=0) is 2b. The ratio of the distance between the two foci to the length of the major axis is e, the eccentricity of the ellipse. So the distance between the two foci is 2ae which means that the foci are located at x=ae and x=-ae.
Now the semi-latus rectum is the line perpendicular to the major axis through one of the foci, to the ellipse. This is just the line: x=ae or x=-ae. The intersection of the line x=ae with the equation for the ellipse defines the coordinates of the end point of the semi-latus rectum. The y coordinate is, therefore its length.
So plug in the value x=ae for the ellipse relation and solve for y. That will give you l in terms of b. Then see if you can work it out from the relationships between a, b and e.
AM
So I just do:
\frac{(ae)^2}{a^2} + \frac{y^2}{b^2} = 1
But what I don't get is what happens to y if you said to solve for y, but the answer is in terms of b? :confused:
sportsguy3675 said:
So I just do:
y is l.
(1)y^2 = l^2 = b^2(1-e^2).
Use the Pythgorean relationship between b, the semi-major axis, and ae (the distance from the origin to a focus): (ae)^2+b^2 = a^2 (recall that a is 1/2 the length of the string which in this triangle is the hypotenuse with sides b and ae). Thus b^2 = a^2(1-e^2) so 1-e^2 = b^2/a^2.
Substituting 1-e^2 = b^2/a^2 into (1) gives you:
l = \frac{b^2}{a}
AM
Ok, I'll just write out my whole proof here because I like the equations better than my handwriting.
e = \frac{c}{a}
so c = ae
The line of the Semi Latus Rectum is x = \pm ae.
So you plug this in for x in the equation:
\frac{a^2e^2}{a^2} + \frac{y^2}{b^2} = 1
e^2 + \frac{y^2}{b^2} = 1
\frac{y^2}{b^2} = 1 - e^2
(1) y^2 = l^2 = b^2(1-e^2)
Plug c = ae into a^2 - b^2 = c^2
c^2 + b^2 = a^2
(ae)^2 + b^2 = a^2
b^2 = a^2 - (ae)^2
b^2 = a^2(1 - e^2)
1 - e^2 = \frac{b^2}{a^2}
Plug back into (1).
l^2 = b^2(\frac{b^2}{a^2})
l^2 = (\frac{b^4}{a^2})
l = \frac{b^2}{a}
Thanks for the help Andrew! :smile:
