Does the Series \(\sum_{n=1}^{\infty} \left[n(n+1)\right]^{-1/2}\) Converge?
The series \(\sum_{n=1}^{\infty} \left[n(n+1)\right]^{-1/2}\) diverges. By applying the comparison test, it was established that \(\frac{1}{\sqrt{n(n+1)}} > \frac{1}{\sqrt{2}n}\) for \(n \geq 2\). Since \(\sum_{n=1}^{\infty} \frac{1}{n}\) is a divergent p-series with \(p = 1\), the original series also diverges. The key takeaway is to approach inequalities from both directions to find conclusive results.
  • Understanding of series convergence tests, specifically the comparison test.
  • Familiarity with p-series and their convergence properties.
  • Basic algebraic manipulation involving inequalities and square roots.
  • Knowledge of limits and behavior of sequences as \(n\) approaches infinity.
  • Study the properties of p-series and their convergence criteria.
  • Learn about the various convergence tests, including the ratio test and root test.
  • Explore advanced topics in series, such as absolute convergence and conditional convergence.
  • Practice solving series problems using different comparison techniques.
Mathematics students, educators, and anyone interested in series convergence, particularly those studying calculus or advanced mathematical analysis.
ognik
Use the comparison test to see if $$\sum_{1}^{\infty}{\left[n\left(n+1\right)\right]}^{-\frac{1}{2}} $$converges?
I tried $$n+1 \gt n, \therefore n(n+1) \gt n^2 , \therefore {\left[n(n+1)\right]}^{\frac{1}{2}} \gt n, \therefore {\left[n(n+1)\right]}^{-\frac{1}{2}} \lt \frac{1}{n}$$ - no conclusion possible here
\frac{1}{\sqrt{n(n+1)}} \le \frac{1}{n(n+1)} \le \frac{1}{n^2}
Instead of $n+1 > n$ as a starting point, try it in the form $n < n+1$. That will give you $[n(n+1)] < (n+1)^2.$ Where does that lead you?
Not true: $\sqrt{n(n+1)} \le n(n+1)$, but when you take the reciprocals the inequality goes the other way round.
So the final comparison is with $$\frac{1}{n+1}$$ - interesting the difference that small change in approach makes - the take away for me is that when I get an inconclusive inequality, I immediately try approaching it w.r.t. the 'other direction' inequality :-)
When justifying my answer, is it enough to refer to the p series with p = 1? Or do I need to be more rigorous - my understanding is that with comparison tests, $$\frac{1}{n+1}$$ is the same thing as $$\frac{1}{n}$$ ?
Yes, it's always good to look at such problems from both sides. (Nod)
It should be enough to say that this is effectively the same as $\sum 1/n$. The only difference is that the first term is missing. But convergence is unaffected by changing a finite number of terms at the start of a series.
For $\displaystyle \begin{align*} n \geq 2 \end{align*}$ we have $\displaystyle \begin{align*} n^2 + n < 2\,n^2 \end{align*}$, so
$\displaystyle \begin{align*} n^2 + n &< 2\,n^2 \\ \sqrt{ n^2 + n } &< \sqrt{ 2\,n^2 } \\ \sqrt{ n \left( n + 1 \right) } &< \sqrt{2}\,n \\ \frac{1}{\sqrt{ n \left( n + 1 \right) } } &> \frac{1}{\sqrt{2}\,n} \end{align*}$
thus
$\displaystyle \begin{align*} \sum_{n = 1}^{\infty} \frac{1}{\sqrt{ n \left( n + 1 \right) }} &> \sum_{n = 1}^{\infty} \frac{ 1}{\sqrt{2}\,n} \\ &= \frac{1}{\sqrt{2}} \sum_{ n = 1} ^{\infty} \frac{1}{n} \end{align*}$
Since $\displaystyle \begin{align*} \sum_{n = 1}^{\infty} \frac{1}{n} \end{align*}$ is divergent, so is $\displaystyle \begin{align*} \frac{1}{\sqrt{2}}\sum_{n = 1}^{\infty} \frac{1}{n} \end{align*}$ and thus $\displaystyle \begin{align*} \sum_{ n = 1} ^{\infty} \frac{1}{\sqrt{n \left( n + 1 \right) } } \end{align*}$ is divergent by comparison.
  • · Replies 17 ·
  • · Replies 19 ·
