Series circuit lab data doesn't match series or parallel
34 replies · 5K views
shmoop
Hi guys!
(see my attached photo to better understand where I am coming from!)
So after some research, I've discovered that the current at different points in a simple series circuit is supposed to be the same value, and that the voltage is supposed to be different values.
I performed a lab on resistors in series the other day, and I believe my data is incorrect.
The majority of the data I got tells me that I may have set my circuit up as a parallel series - however the fact that the total measured current is not equal to the sum of the separate currents measured at each resistors conflicts with this. (see attached image of my lab data for clarity!)
Furthermore, due to the value of the total current as well as the value of the total voltage, the total R calculated using Ohm's law is equal to the Req that was calculated through adding the individual resistances up (which were also calculated through Ohm's law).
I am wondering, what did I do to obtain this kind of data information? As it does not conform what I would designate as a series circuit, nor a parallel circuit.
Does anyone have any idea what I have done to obtain this lab data? What kind of circuit did I create?
Thanks a lot in advance.
Edit: Here are the resistor values:
R1=100 ohms
R2= 220 ohms
R3= 470 ohms
I think you wired it in series but wrote the current values in the voltage column and the voltage values in the current column.
Edit: oh darn that can't be the only problem as I doubt you were playing with 50volts.
I considered that too. But I followed the formula R=V/I, and the values worked out that way. If I divide the current values by the voltage values instead, the resistance doesn't work out like it should...
you SHOULDNT be dividing current by voltage ... .it will never give you the correct answer
I know haha! But I was responding to CWatters who had mentioned that it looked like my current and voltage values were reversed. In which case I would do the opposite of what I had previously done, therefore dividing the current by the voltage.
your attached image is VERY difficult to read
What is the battery voltage ?
are the resistance values given ... even at least one of them ?
Here is a zoomed in version of the photograph!
The supply was approximately 5 volts.
R1=100 ohms
R2= 220 ohms
R3= 470 ohms
Sorry about that!
you only need to work out the current through 1 resistor to work out the total current in the circuit
you DONT add it up as you do with the voltage drops across each resistor
How would you mathematically determine the total current in the circuit with the current through 1 resistor?
I know that you don't add it up for a series circuit - I was trying to say that that is what I would have done for a parallel circuit. I wrote series accidentally! Sorry. I meant to say the majority of my data makes it look like I set up the situation as a parallel circuit. (all the different current values, and the fact that the voltage stays the same)
OK that is easier to read
the figures in your current column cannot be correct
and I don't know why they are asking you to calculate resistor values for column 3 when the values are already given to you ??
I assume they ask so that you can then use the values to perform the Rtotal=1/R1+1/R2+1/R3
To prove that it is a series circuit
you treat all series resistors as 1 resistor ... add up those 3 values for a total resistance value
give me that answer
then divide the voltage (5V) by the total resistance to get your current
give me that answer
then you can look at the voltage drops across each resistor
Vdrop R1 = resistance x current =
Vdrop R2 = resistance x current =
Vdrop R3 = resistance x current =
adding up those 3 voltages should equal your supply voltage = 5V
no, that formula is for parallel resistors
Oopsies. I meant to make sure it matches the total R with the Rtotal=R1+R2+R3
OK
so copy and paste that post #12 of mine and fill in the answers
and show your working, not just the answer
give me that answer
give me that answer
My voltages are 5V throughout. Which is confusing. Because they equal 15V when summed, as opposed to 5V. However, when calculating my individual resistance values, when summed they equaled the total resistance initially calculated. This is what confuses me
they cannot be 5V throughout because that is your total voltage
do the sums that I have asked you to do and get your working and answers
have you copied and pasted this ?
give me that answer
give me that answer
adding up those 3 voltages should equal your supply voltage = 5Vjust a note I didn't state when I typed that out originally
should be ( for clarity)
Vdrop R1 = resistance R1 x current =
Vdrop R2 = resistance R2 x current =
Vdrop R3 = resistance R3 x current =
give me that answer
give me that answer
The values that were measured were the voltage and the current. The resistances were calculated from these. For me to perform these calculations seems aimless, as I will just get ~5V for each voltage drop. Which is part of my main issue.
it's not aimless as you will find your mistake
AGAIN, there is NOT a 5V drop across each resistor --- it's impossible to have a 5V drop across each resistor
Copy and Paste ( DONT QUOTE IT) my post and do the sums as I have laid them out and you will see where you have gone wrong :smile:Dave
I am confused
shmoop said:
I am confused
Im not surprised
what is Ohms law ? as you didn't use it correctly to find the current
and since you got the incorrect current, everything following that is incorrect
I also notice you didn't use the resistor values you stated in post 1
100 Ohms 220 Ohms 470 Ohmsyou didn't do your working on the post so I couldn't copy and paste individual parts
davenn said:
Im not surprised
Woops. Huge mistake there. I will redo it. I thought I was supposed to use my experimental values.
we will get you there, you just need to get the basics correct :smile:
If I give you the answers, you won't learn anything, because you still won't understand where you went wrong :wink:
that's OK we can work with the actual values rather than the idea values you originally posted
it's just your answers will be a little different, that's all :smile:
I see! So these are the voltage drops!
YES ! well done :smile:
none of the individual drops can = 5V, they all must be smaller
and when added together will = 5V ( or whatever the supply voltage is)
Now you could redo the math using your actual resistor values
you should again end up with 5V ( as a total drop) give or take a couple of decimal points
each individual drop will be a little different to what you just worked out for the ideal resistor values
Now that we have the resistor values I think I can see what you did in the experiment.
It looks to me like you started with the resistors in series and measured the overall current correctly (but forgot the current values were in mA not A).
For example the total resistance is 790 Ohms so the current should be about 6.37mA but you wrote down 6.37A. Then when calculating the total resistance you did R=V/I (which is correct method) but you used:
R = 5.03/6.37 = 0.789 Ohms
instead of
R = 5.03/(6.37 * 10-3) = 789 Ohms (very close to 790 Ohms).
Then when you came to measuring the current through each resistor you connected each resistor to the power supply on it's own, which is incorrect. So the voltage across each resistor was the same about 5.03V.
The currents should have been...
For R1... I = 5.03/100 = 50.3mA (You recorded 50.2A)
For R2... I = 5.03/220 = 22.8mA (You recorded 23A)
For R3... I = 5.03/470 = 10.7mA (You recorded 10.9A)
So again it just looks like you forgot the values were in mA.
Again this made all your resistance calculations out by a factor of 100. Your calculations should have given you..
R1 = 100 Ohms
R2 = 218 Ohms
R3 = 463 Ohms
These are all within tolerance.
Of course you should have left all the resistors in series and measured the voltage across each.
How did you calculate the resistance with those current values?
In a series circuit, the current value is supposed to stay the same, and the voltage value is supposed to vary.
