Series Circuit with two batteries
16 replies · 4K views
Ryoblck
A. Make a prediction about the direction of current flow through each resistor. (6 points)
B. What current flows through each resistor? (15 points)
C. What is the voltage drop across R2? (4 points)
Req=R1+R2+R3
I'm sort of lost as to how to go about the equation. Normally I could tell the direction of the current when given a positive or negative sign near the battery.
Req=R1+R2+R3
The wider end of the battery is +.
So the top half of the circuit goes counter clockwise while the bottom half goes clockwise?
Certainly, the bottom loop goes clockwise.
While you may be correct regarding the top loop, I wouldn't hazard a guess without further analysis. (analysis of the circuit, not my personal analysis with my shrink!)
Ryoblck..
One way to analyse this type of circuit is to mark on the circuit arrows showing which direction you are assuming the current and voltage drops to be in the resistors. These have to be self consistent but it doesn't matter if you are wrong!
Then you apply KCL and KVL to write a series of simultaneous equations. It's important that these are written correctly taking into account the direction of the arrows.
When you solve these simultaneous equations some values may come out -ve. That just means you got the direction of the arrow wrong when you made your assumption. No matter. Don't change the arrows because that will make your working out appear wrong.
CWatters said:
Ryoblck..
So I should solve the circuit by guessing the type of direction the current is flowing? Then the answer will tell me whether I'm wrong or not?
If your answer is negative you picked the wrong direction, but your answer is still correct since two minuses make a plus! In other words, a current going in one direction is the same as the negative of the same current going in the other direction.
Ok. Well I solved it out and after making some changes to the direction, I think I got it right. The top half will flow clockwise while the bottom will flow counter-clockwise. That is what I got. And regarding the current, I got the Current in R1 to be 3 amperes, Current in R2 to be 1.5 amperes, and Current in R3 to be 2 amperes. Does that sound right?
Sorry it can't be right.
There is no way to make 3, 1.5 and 2 add up to zero as required by KCL at (for example) the node at the top left.
Oh ok. I found that I had three equations for only two unknowns. Let me double check my equations first.
After trying some equations for an hour, I'm still lost. The only problem with my equations is the unknowns of the current. I don't know where to begin to find it. I realized that I actually need three equations for the three unknown currents.
I2=I1+I3
i) I1R1-E1-I2R2
ii)E2-I3R3-E1-I2R2
I started from the top left and the middle left.
Can you mark up the diagram with your initial assumptions about the voltage drops and currents.
I would start by marking the top left node Va and the bottom right node Vb=0V (arbitrary choice). Then apply KCL to one of these nodes.
I2=I1+I3
I prefer to write that in the form..
I1 +I3 -I2 = 0
Hint: You can write equations for each current in terms of Va.
I1 +I3 -I2 = 0
I labeled top right resistor R1, the middle battery E1, middle resistor R2, bottom left battery E2, and bottom resistor R3. I didn't include Va or Vb anywhere because I never understood that stuff
I've redrawn the circuit and labeled up the currents. I made the arbitrary decision that they all flow into node Vb which clearly can't be true...
Applying KCL to node Vb you get
IR3 + IR2 + IR1 = 0 ... (eqn 1)
What we would like are equations for each of those currents. One way to do that is as follows...
Looking at the bottom row of the drawing you have the path...
Node Va --- 6V bat --- R3 ---- Node Vb
Using Ohms law we can write an equation for IR3 as follows..
IR3 = (Va - 6V - Vb)/R3
Since we have choosen Vb = 0 that reduces to
IR3 = (Va - 6V)/R3 ........ (eqn 2)
Using the same approach you can write..
IR2 = (Va - -12V)/R2 = (Va+12)/R2 .... (eqn 3)
and
IR1 = Va/R1 .......... (eqn 4)
Now put eqn 2,3,4 into 1...
(Va - 6V)/R3 + (Va+12)/R2 + Va/R1 = 0
Substituting values for the resistors that reduces to
Va = -24/11 Volts
Then each current can be calculated individually...
IR1 = Va/R1 = -1.091 A
IR2 = (Va - -12)/R2 = 2.455 A
IR3 = (Va - 6)/R3 = -1.364
As a check add up the currents...
-1.091 + 2.455 -1.364 = 0
Note that...
IR1 is negative so the current in the top is flowing in the oposite direction to my arrow (eg anti clockwise!)
IR3 is also negative so the current in the bottom loop is flowing in the oposite direction to my arrow (eg clockwise!).
Perhaps revise the prediction, draw the arrows the other way where necessary and repeat the calculations :-)
Thank you so much! That actually made sense in the end. Now about the third question, its about the voltage drop across R2. I used the V=IR equation substituting R2 with 4 ohms and I2 with 2.455 A and found that it was 9.82 V. Does that sound right?
Oh ok that makes sense. Thanks for all of your help. :)
