Series Convergence: Does This Series Converge and What is the Sum?
Somefantastik
Does it converge, and what is the sum:
\sum_{n=1}^{\infty}\frac{1}{n n^{\frac{1}{n}}}
Please check my method and conclusion:
Using the root test:
\displaystyle\lim_{n\to\infty}\left|\frac{1}{n n^{\frac{1}{n}}} \right|^{\frac{1}{n}} = \displaystyle\lim_{n\to\infty}\frac{1}{n n^{\frac{1}{n}}} = \displaystyle\lim_{n\to\infty}\frac{1}{n}\displaystyle\lim_{n\to\infty}\frac{1}{ n^{\frac{1}{n}}} = 0
so while this doe not give me the sum (I'm not excited about that part...), it at least tells me that this series converges. Am I correct?
Your first step is incorrect. How did you just get rid of the 1/n exponent?
I don't see that you actually took the root. You lost the 1/n exponent right away without changing anything.
You could have simpified things by writing nn1/n as n1+1/n. This looks like a convergent p-series to me.
NOT a convergent p-series, Mark44. The limit of n^(1/n) as n->infinity is one. Think about a comparison test.
I had a suspicion that it wasn't a p-series, given that the exponent wasn't a constant. Thanks for straightening me out, Dick.
I'm not sure it matters that the exponent is a constant, as long as it is an integer n>0, because no matter what n is here, the value will be greater than 1. BUT since 1/n converges to 0, then we have the exponent converging to one, and then we have a problem.
I'm still not sure what to do here. As far as comparison goes:
\sum \frac{1}{nn^{\frac{1}{n}}} \leq \sum \frac{1}{n}
But that is not helpful b/c the 1/n series diverges...
You've got (1/n)*(1/n^(1/n)). The second factor approaches 1. So for large n the second factor is greater than, say, 1/2.
\sum \frac{1}{nn^{\frac{1}{n}}} \geq \sum\frac{1}{2n}
Since we know that the second series is divergent and smaller than the original, we can say the original must diverge as well.
Best possible outcome, really. Now you don't have to worry about summing it.
:-) Thanks for the input.
