Undergrad How Does the -1 Arise in This Series to Function Conversion?
The discussion centers on understanding the appearance of the -1 in the conversion of an infinite sum to a function. The sum in question, starting from n=1, lacks the constant term from the series expansion of e^x, which typically begins at n=0. This missing term accounts for the -1 in the equation. By recognizing that the constant term is omitted when starting the sum at n=1, the reasoning becomes clear. The clarification highlights the importance of considering all terms in series expansions for accurate conversions.
transmini
I ran across an infinite sum when looking over a proof, and the sum gets replaced by a function, however I'm not quite sure how.
$$\sum_{n=1}^\infty \frac{MK^{n-1}|t-t_0|^n}{n!} = \frac{M}{K}(e^{K(t-t_0)}-1)$$
I get most of the function, I just can't see where the ##-1## comes from. Could someone help show that?
The first term in the expansion of ##e^x## is ##1##, usually put in the sum with index ##0##. In your case the sum starts with ##n=1## so the constant term is missing on the left side. If you move the constant term from the right side to the left you will see it.
Oh, not sure how I missed that. That makes sense, thanks
