Series RLC circuit connected to a DC battery
The discussion revolves around solving a differential equation related to a series RLC circuit connected to a DC battery. Participants explore the behavior of the circuit over time, particularly focusing on the voltage across the capacitor and the implications for the current in the circuit.
  • Participants discuss the formulation of the differential equation and the implications of long-term behavior in the circuit. Questions are raised about the voltage across the capacitor after a long time and the resulting current through the resistor and inductor.
There is an ongoing exploration of different approaches to solving the differential equation, with some participants suggesting a focus on the steady-state solution. Guidance has been offered regarding the nature of the solutions and the behavior of the circuit as time approaches infinity.
Participants note that the problem involves a second-order ordinary differential equation with constant coefficients, and there is a recognition of the relevance of the damped harmonic oscillator in this context. Some participants express a preference for solving the differential equation directly rather than focusing solely on the steady-state behavior.
Meow12
A series RLC circuit is connected to a DC battery via a switch. A long time after the switch is closed, what is the current in the circuit?
Kirchhoff's voltage law gives ##\displaystyle iR+\frac{q}{C}+L\frac{di}{dt}=\mathcal{E}##
How do I solve the differential equation? Please give me a hint.
I guess I could write ##\displaystyle i=\frac{dq}{dt}## to get
##\displaystyle R\frac{dq}{dt}+\frac{q}{C}+L\frac{d^2q}{dt^2}=\mathcal{E}##
Then how do I proceed?
For the dt terms, what does t approach, After a long time?
-OR-
A couple clues to a different approach:
A series RLC circuit is connected to a DC battery...
A long time after the switch is closed...
Now:
What is the voltage on a Capacitor after being connect to a voltage source for A long time...?
Tom.G said:
Now:
I think it will be ##\mathcal{E}##, the emf of the DC battery.
I just edited my post at the same time you responded. Take a look.
##t\to\infty##
Yes to both Vc and t.
With the Capacitor voltage equal to and in series with the battery voltage, what is the voltage applied to the R and the L?
I guess ##V_R=V_L=0##. And since ##V_R=iR##, this means ##i=0##?
I would've preferred to solve the differential equation, though.
Correct.
Sorry about the shortcut, too much practical field experience I guess.
I'll see if I can get one of the more math-oriented folks here to help on that approach.
Just entered a request for the math help.
  • Love
This is a regular 2nd order ODE with constant coefficients. You can solve it with any applicable method for solving ODEs. However, the easiest way is to note that a constant solution ##q = \mathcal E C## solves the ODE and is time-independent. Unless the ODE has a oscillatory solution with constant amplitude, that will therefore be the large time solution.
To add to that: You can of course solve the entire ODE and take the limit ##t\to \infty## as well. Start by defining ##w = q - \mathcal E C## to obtain a homogeneous ODE for ##w##. Solve for the general case with the ansatz ##w = e^{kt}## and determine ##k## (since you have a second order ODE, there will be two solutions for ##k##, the general solution is a linear combination -- ##A e^{k_1t} + B e^{k_2t}## -- of those as the ODE for ##w## is a linear and homogeneous ODE).
This problem for q is the damped harmonic oscillator. The equation is ubiquitous and holds for nearly any dynamic sysytem close to equilibrium. Masses on springs or an approximated pendulum It is solved in every good freshman physics text, with colors and pictures. Learn it inside and out. Soon you'll be doing quantum field theory.
  • · Replies 21 ·
